Old 02-26-2015, 09:04 PM   #1
Chips-resto
88 J3500 4x4 front axle spindle nut
Is there a cure for these thing from loosening up all the time?
Chips-resto is offline   Reply With Quote
Old 02-26-2015, 09:48 PM   #2
Chips-resto
Re: 88 J3500 4x4 front axle spindle nut
Its the dana 60 front axle. I thought I read somewhere here somebody making a kit with tabs to help keep the axle nut from loosening up
Old 02-26-2015, 10:35 PM   #3
ryanroo
ryanroo's Avatar
i have never had that issue. what style nut and locking nut are you using? i think my k20 has the tabbed washer. and i think the green truck has the pin washer style. stage 8 makes a locking nut kit. guaranteed not to loosen.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-27-2015, 12:19 AM   #4
$20071k10
$20071k10's Avatar
There should be a washer with a bunch Of holes all the way around it And keyed In between the two spindle nuts. The first spindle nut should have a nipple all on it the nipple engages the holes in the washer the key way keeps the nut and washer from spinning and the second nut james it all together if you are torquing the out side jam nut right it should never come loose!!!
$20071k10 is offline   Reply With Quote
Old 02-28-2015, 11:51 AM   #5
Mr. 250r
Mr. 250r's Avatar
The problem with them i noticed after doing the brakes on my 89 V3500 is that people put the washers on wrong and break the nipples off thus making them useless i think the kit you are talking about is this http://www.stage8.com/xlock.html.
I bought them from summit racing and installed them and yes they can't really come off because the snap ring design holds it all together, here's my write up on a dana 60 rotor replacement that shows pics of both setups. http://67-72chevytrucks.com/vboard/s...d.php?t=601544
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-01-2015, 10:16 AM   #6
obijuan
Just put 14 bolt nut and key type on it.so much easier.
obijuan is offline   Reply With Quote
Old 03-02-2015, 03:43 PM   #7
doubleclucker
doubleclucker's Avatar
obijuan is right!
The bottom Nut, keyway and snapring in pic from around 85'-up 14bolt will fit Dana 60 front
(this should be what you have in rear now if you have a 14 boltff)
This way you only need that 1 special socket for both ends.
100:1 low gear!
doubleclucker is offline   Reply With Quote
