Old 03-01-2015, 01:13 AM   #1
brwn70gmc
99 K2500 rear axle hub seal leak
My 99 3/4 ton Suburban has a Corporate 14 bolt rear end. The passenger side rear hub seal leaks, and needs replacing every 2-3 years (along with soaked brake shoes) Is the whole housing assembly bad since the hub seal rides on
it? I also have a whine under power, which goes away on coast, thinking that might be a pinion bearing?
brwn70gmc is offline   Reply With Quote
Old 03-01-2015, 08:45 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 99 K2500 rear axle hub seal leak
It could be a pinion bearing making the noise. Down shift to 3rd or 2nd. Let off the gas. Does it make the same noise? I pinion bearing will make load when there is any kind of twisted load on the axle, whether it's up or down.
Clean off the spindle where the sequel rides with emery cloth. Get it as clean as you can.
You'd have better luck in the 88-98 section.
95 S_Trucker is offline   Reply With Quote
Old 03-01-2015, 08:52 AM   #3
72MARIO
72MARIO's Avatar
When you replace the seal are you using small amount of a Rtv on the seal ? My dad had problems with his and we learned thag s the proper way to install them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-03-2015, 05:16 PM   #4
83GMCK2500
How does the surface of the axle tube look where the seal rides? Read THIS POST concerning a possible issue.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-27-2015, 02:10 PM   #5
brwn70gmc
The Speedi-Sleeve option looks great. Does the Speedi-Sleeve go by application or size?Is it safe to order that specific part# or should I have it mic'd to ensure the shaft size?
99 k2500, axle
