Old 03-14-2015, 10:54 PM   #1
1970chevc101994
1970chevc101994's Avatar
Any pictures of 2wd cab to 4wd?
I am converting my 70 chevy c10 to 4wd. I am looking for any pictures of the fabrication pictures of how they may the center hump in the cab for the transfer case? Thanks
2005 Chevy Silverado 2500HD- DD
1970 Chevy C10 SWB 454 BBC- Work In Progress
1970chevc101994 is offline   Reply With Quote
Old 03-14-2015, 11:00 PM   #2
andrewmp6
Re: Any pictures of 2wd cab to 4wd?
It would be easier to cut one out of a 4x4 truck if you can.
andrewmp6 is offline   Reply With Quote
Old 03-14-2015, 11:02 PM   #3
1970chevc101994
I could do that. It would be out of an 85 chevy though. That's the parts truck that I am getting to transfer case, transmission, and axles from
Old 03-15-2015, 01:03 AM   #4
Maxxd07
Maxxd07's Avatar
Is your c10 automatic or manual? The manuals had the removable tall center hump and you would have to just make a hole for the TC. If its an automatic it would almost be better to find a manual cab to take the hump out of and part of the floor since the floor is just a little different at the rear, if you want it factory like that is.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 03-15-2015, 01:50 AM   #5
1970chevc101994
It was a manual then previous owner made it an automatic. So maybe it does already have the larger hump. I will post pictures tomorrow
Old 03-15-2015, 03:32 AM   #6
Maxxd07
Maxxd07's Avatar
Without running out to look, I believe the small hump isn't removable but the large one is bolted in.
Couple 80s
Couple 70s
One 68
Old 03-16-2015, 07:16 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I put a 70 C20 cab (2wd auto) on a 71 chassis (K20 manual) and bought a "high" hump off of a board member. It was fairly easy to do, set the high hump in place, mark the floor and move in an inch or so and cut it out. I used self tapping screws to bolt it in. I do not think the 85 will work.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-16-2015, 07:42 AM   #8
67swb72klb
67swb72klb's Avatar
Thumbs up Re: Any pictures of 2wd cab to 4wd?
Simple as that
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-17-2015, 12:21 AM   #9
swamp rat
swamp rat's Avatar
The high hump can also be from an automatic, my 72 has a TH350 and has one, it has a hole for the T case only, you could find one on the parts for sale board for probably about $40-$50.
I've seen the conversion on a thread here where yes they just lay it over the top and trace it, when you cut the old one out just measure back an inch to 1 1/4 and cut the low hump out, sand and paint the cut area, use some seam sealer when you screw the high hump into place.
Heres a post in my build thread showing my high hump is a bolt in, http://67-72chevytrucks.com/vboard/s...&postcount=439
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
