Old 03-19-2002, 09:57 PM   #1
ebfabman
Post replacing ''A" arm bushings &balljoint pics
remove A arm and remove balljoint
remove old bushings & shaft
disassembled
screw in one bushing
screw shaft into bushing
screw in 2nd bushing
next the balljoint
use the grade 8 bolts
install back on truck
tighten everything up & grease
Some tips. Screw in the first bushing all the way into the A arm. then after greasing the shaft, screw it all the way into the bushing, then unscrew it out one turn. Then screw the other bushing into the A arm. Snug them down good. I have seen the bushings tack welded to the A arm, just be sure to tack them so they can be removed later.
There may be other ways to do this, but this is how I've done it over the years. If anyone has anything to add please feel free.....eb
ebfabman is offline   Reply With Quote
Old 03-20-2002, 12:14 AM   #2
daveo68
daveo68's Avatar
Post
That is great we need more info like that on this board. I know this will help me when I start on my suspension. Keep up the good work.
Dave
68 C-10 Custom LWB
307 V8
Three-on-the-tree
Lexington,NC
davideowens@lexcominc.net
68 C-10 Custom LWB
307 V8
Lexington,NC
God Bless America
daveo68 is offline   Reply With Quote
Old 03-20-2002, 12:39 AM   #3
Spoof
Spoof's Avatar
Post
Very timely, I'm about to do my balljoints. Ordered moog uppers, one was missing the hardware, called parts plce which ordered a new one, same part different hardware, missing bolts. Moog has some serious quality control probs.
I wasn't planning on doing my A arm shaft, but prolly idler and pitman and lowers. Is there a test for the state of your A arm bushings?
71 GMC 2500 Custom Camper
71 GMC Suburban 1500 Super Custom
71 Chevrolet 1500 Donor
http://www.able-bravo.com
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-20-2002, 12:56 AM   #4
Brad69
Crash Test Dummy
Post
Can we get Josh or one of the admins to move this to the "Tech Tips" or "Tech articles" section?
The more hair i lose, the more head i get.
Build Sheet:
1969 C-10 short fleet
Constructed by taking a 3/4 ton rolling frame from one truck, adding a rust free AC Cab from another, then a bed from another, 1/2 ton front suspension & brakes from another,add in one Goodwrench crate 350, painted DuPont Arctic White,and driven daily.
Brad69 is offline   Reply With Quote
Old 03-20-2002, 01:01 AM   #5
jostrans68
Jostrans68
jostrans68's Avatar
Post
After 20 yrs parts experience its not moog you should see the way this stuff is handled at the Independent Whse's I watched the guys throwing parts to a guy ona ladder 4 out of 10 missed,The mfg's cant control this....
My 2 cents
68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 03-20-2002, 01:02 AM   #6
imdarren
imdarren's Avatar
Post
eb, Thanks soooo much for posting that kind of stuff! It took extra time out of your project to do that, but newbies like me can't get enough of that sort of thing! THANK YOU!! Darren
Darren
Washougal, Washington
darrengale67@hotmail.com
NOT the NetZero e-mail.
1972 GMC C1500 (Bone Stock)
Saving / Looking for a 72 3/4 Ton 4X4 Automatic with little or no rust.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 03-20-2002, 01:53 AM   #7
ebfabman
Post
You are certainly welcome Darren, but really I just like playing with my camera....LOL
Old 03-20-2002, 08:15 AM   #8
70chevy
70chevy's Avatar
Post
Thanks for all of your time to explain with pictures. I am in the process of doing just that. Where did you order the bushings?
Great work.....
Ken Smith
99 C5 Torch Red Coupe
85 Chevy Candy Apple
70 Chevy 1/2 in process.Semi-gloss black powdercoated frame & suspension, disc brakes up front, 3" drop spindle(Beltech) 5 lug 3.73 rearend, ZZ4, Sanderson headers, 700R4, Air Ride system, Summitt 16 gal fuel cell, Holly mech. fuel pump,
70chevy is offline   Reply With Quote
Old 03-20-2002, 10:14 AM   #9
slam33
slam33's Avatar
Post
you don't want to do the final torque on the shafts untill you get the truck back on the ground. I put jack stands under the bottom a-arms and load the suspention. Then you do the final torqueing on the shafts
71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
</A>
slam33 is offline   Reply With Quote
Old 03-20-2002, 10:52 AM   #10
69 longhorn
Post
all pretty well covered ebfabman,the only thing that I can add.....have plenty of beer on hand! .......69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-20-2002, 09:06 PM   #11
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Wink
Has anyone else noticed that the bolts in they're ball joint kit were metric. Damn, I got metric bolts on my truck!
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
