Old 09-02-2003, 09:26 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
More rust problem's
I guess this would be a good question for gee eem as he seem's to be the rust king.. If I have rust in the lower kick pannel's below the air vent, should I put the top back on to fix it or just make some brace's of some sort???? Any idea's or feed back would be great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 09:58 PM   #2
blazerholic
I am a Gov't Mule
blazerholic's Avatar
There is a patch panel for that. Got mine from LMC. O K , just realized that maybe your ? is what to do when repairing with the patch panel... I'd say make some braces. Mine isn't in yet but that's what I plan to do since I still appear to get some flex/droop of the body tub with the top on.
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 09-02-2003, 10:18 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
When I put the blazer top on it push's up the windshield frame and alow's the door's to open very easily. I promised myself I would not start this blazer project untill my pick-up was done, WHAT THE HELL HAPPENED!!!!!ANOTHER PROJECT AND THE PICK-UP IS ON THE BACK BURNER, AGIAN!!!!!!
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 10:38 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Here's the crappy job the p.o. did to cover up the mess look's like bondo too. Almost make's me afraid to grind off the green paint as I may have no metal and all filler..
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 10:39 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
And the passenger side...
MEMBER #6377
Project "7DEUCE"
Old 09-02-2003, 11:04 PM   #6
Gee_Emm
Personally I would do the repair with the top on.
If you do it with the top off there could be misaliginment and when you go to put the top on the mounting screws might not align. There is a very slim chance of it going out of wack by cutting that piece out because that metal isnt largly structural. Are your rocker boxes on there or non exsistant? The kick panel kind of folds over underneath at where it meets the floor so there may be some need for repair there. I will attach a picture that shows this area. It aint a fun place to work in.
Gee_Emm is offline   Reply With Quote
Old 09-02-2003, 11:23 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
That's the funny thing. The rocker boxe's are almost perfect 2 small pin hole's of rust...
MEMBER #6377
Project "7DEUCE"
Old 09-03-2003, 12:20 AM   #8
1970blazin
Blazerless:-(
1970blazin's Avatar
You guys have me scared now...My husband did our whole floorboards, kick panels, and door pillars with the top off and no braces or anything. He is really good at fitting and welding since that is his job- (he owns his own welding business), but now I am a little worried that the top won't fit quite right when we put it on.... I guess I will let ya know later. Hopefully this doesn't make for leaks later...hmmmm.
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 09-03-2003, 05:02 AM   #9
Phillip Johnson
Phillip Johnson's Avatar
Hey Luke, Instead of buying that welder you told me about, now that I see the rust damage, come on over tomorrow. I picked up a new roll of duct tape and a gallon of bondo.. We can do it!
Phillip Johnson is offline   Reply With Quote
Old 09-03-2003, 07:29 AM   #10
FRENCHBLUE72
PROJECT 7DEUCE
Thank's phil but I do not want bondo.. I am gonna buy the welder.. BTW 70blazin if your blazer don't leak let us know how you did it...Every blazer I have seen has leaked..
MEMBER #6377
Project "7DEUCE"
