Old 06-02-2015, 12:46 PM   #1
pvienneau
pvienneau's Avatar
1987 gm axles 3.42 gears from a 1/2 Ton pickup 6 lug
Will the axle of a 1/2 Ton GM pickup 6 lug fit the AD 1949 3100?
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 06-02-2015, 01:47 PM   #2
OrrieG
OrrieG's Avatar
Re: 1987 gm axles 3.42 gears from a 1/2 Ton pickup 6 lug
Check the pad mounting location (can be changed) and track width, drum to drum. You will probably find it is wider which will make the tires stick out beyond the fenders with standard wheels.
OrrieG is offline   Reply With Quote
Old 06-02-2015, 03:15 PM   #3
NEWFISHER
NEWFISHER's Avatar
67 68 and 69 only 3 years that the wms (wheel mount surface) to wms is 1/2" wider. Moves the tire 1/4 inch and retains 6 lug and a 1310 u joint.
Yes, cut the coil pads off and weld some perches after loosely assembling the axle in the truck.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
