Old 06-11-2015, 09:18 AM   #1
TypeSL2
Air Bag Install Question
I was going to post this in the suspension section, but this is more a 60-66 specific question. I am currently installing bags on my '64. After I installed the upper bag bracket on the driver's side last night, I attempted to install the bag. I got the bag mounted and started to raise the lower control arm while watching the bag for any rubbing. I found the bumpstop bracket touches the bag when it starts to go past half way. Here's a pic of the bracket I am referring to.
Do you guys notch this bracket, or just remove it all together? I am not sure if I am supposed to leave the bumpstops in place or not. So any help there as well would be greatly appreciated.
James
TypeSL2 is offline   Reply With Quote
Old 06-11-2015, 09:20 AM   #2
BMERDOC
BMERDOC's Avatar
Re: Air Bag Install Question
Remove the whole thing. Use a eurathane "button head" bump stop if you feel like you need one.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-11-2015, 10:27 AM   #3
blown240
blown240's Avatar
Some bags have internal bump stops. Slam Specialties do. Pretty sure that Firestone doesn't.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 06-11-2015, 10:45 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Actually this is not specific to 60-66 but 60-87. I moved it to the suspension forum.
To answer your question, yes this bump stop is typically removed or trimmed back greatly to clear the bag.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-11-2015, 11:28 AM   #5
JWall
Frequent Flyer
JWall's Avatar
On my truck (73-87) I cut it in half basically. I wanted to retain the steering stop on mine but needed to clearance it for the bag.
On my set up the upper bag plate actually rest on the remaining part of the metal part of the bump stop when full laid out. Which for me is perfect because it makes contact at the same time the tires hit the inner fenders so that not all the weight of the truck is resting on the inner fenders when its laid out.
- Justin
1 Owner 1976 SWB
Old 06-11-2015, 01:46 PM   #6
TypeSL2
Awesome. I wasn't sure if they used the same style bump stop on anything past '66. Thanks for moving it. I am thinking I am going to just cut the bumpstop completely off and then figure out where and how to add one back in later.
James
Old 06-11-2015, 04:40 PM   #7
naynay
cut mine off as well
naynay is offline   Reply With Quote
Old 06-14-2015, 08:53 AM   #8
TypeSL2
So where are you guys mounting your compressors? I want my air tank behind the seats where the fuel tank used to be. With such a short hose from the compressor to the tank, I didn't think I had many options. The compressor is crazy loud in the cab. Thoughts?
James
Old 06-14-2015, 10:09 AM   #9
Tree-50
James
That braided leader hose can run a line off the end of it however long you want. I packed my 3 gallon and valve string on the outside of the frame where the saddle bag gas tank used to be. Compressor is under the cab on the frame rail.
Tree-50 is offline   Reply With Quote
Old 06-14-2015, 01:32 PM   #10
BMERDOC
BMERDOC's Avatar
Porterbuilt makes a nice box that hangs off the side of the frame behind the cab and under the bed. The compressor sits in it and a 3 gal tank hangs off the side. I think they are $80 each.
Nick Carter
Old 08-11-2015, 12:27 AM   #11
rudyyloverboiii
I too would like to bag my 64 looks like fun buy I wouldn't want to ruin it
rudyyloverboiii is offline   Reply With Quote
Old 08-12-2015, 09:37 AM   #12
Pro Performance
Pro Performance's Avatar
The PB brackets do make things a little easier to mount. If needed, you can always run some airline off the leader hose if you need more length. We do carry the PB brackets in stock, if you decide that is the route you want to go.
If you do need anything line and fittings, we can get all that as well. Most guys will mount the air ride equipment underneath, and along the frame somewhere.
Pro Performance is offline   Reply With Quote
