Old 06-27-2015, 12:05 AM   #1
71ChevySS(straight6)
Turn Signal / Hazard Switch, please help!
Hello again! So, here's my next issue. The plastic turn signal switch inside the steering column stripped out where the screw holds the lever in place. No big deal, I'll just pull the steering wheel off, pull it out and replace it. Truck said "not so fast, hot shot."
The hazard switch in my truck is the little red plastic tab that pulls/pushes. I can't figure out for the life of me how to pull that switch assembly with that hazard switch in place. Help me please! Thanks!
attached is a picture to show you the part I'm talking about.
'71 Custom-10 2wd longbed, 250 inline-6, NP 435 four-speed. Medium Bronze Iridescent. Farm truck deluxe.
Rat rod build: 1949 Crosley Station Wagon body on 1993 Dodge D350 chassis, Cadillac 500 powerplant.
71ChevySS(straight6) is offline   Reply With Quote
Old 06-27-2015, 12:40 AM   #2
70shortfleet
70shortfleet's Avatar
Re: Turn Signal / Hazard Switch, please help!
Take the 3 screws that hold the turn signal to the housing and the hole top assembly will come apart
70shortfleet is offline   Reply With Quote
Old 06-27-2015, 12:59 PM   #3
Cool, I'll try that. Thanks
Old 06-27-2015, 02:29 PM   #4
davepl
davepl's Avatar
It's still not easy to get out, as I broke mine the first time I tried. Just be careful sneaking it out of there once the three aforementioned screws are out; you basically have to slide the red thing in and through so it means manipulating the whole assembly to do that without busting the red button off.
That 40 year old plastic gets brittle.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
blinkers, steering column, switch, turn signals
