Old 06-27-2015, 12:47 AM   #1
stepsider
stepsider's Avatar
Rear window tint film
I want to remove the tint film on the rear window of my cab. Want to know the easy & correct way[/SIZE]
stepsider is offline   Reply With Quote
Old 06-27-2015, 07:24 AM   #2
hugger6933
Re: Rear window tint film
Single edge razor blade and window cleaner. A heat gun will help when removing the film and if you don't have one use a hairdryer. It will loosen the film from the window and let it stick to the film as your pulling it off. Otherwise start scraping the glue and that is where the glass cleaner comes in to make the glue soft and it will come off easier. jim
hugger6933 is offline   Reply With Quote
Old 06-27-2015, 07:36 AM   #3
Grumpy old man
Grumpy old man's Avatar
use warm ammonia/water in a spray bottle it will release the film ,There is also a citrus based cleaner that works as well . DO IT IN THE SHADE ON A COOL WINDOW
Grumpy old man is offline   Reply With Quote
Old 06-27-2015, 11:59 AM   #4
jakewalter
jakewalter's Avatar
I was always told to use a stainless steal razor blades so that it doesn't scratch the glass.
jakewalter is offline   Reply With Quote
