06-27-2015, 10:24 AM | #1 |
What does 952 mean stamped on firewall ?
I just bought this 1972 c10 and I noticed the numbers 952 stamped on the firewall and also the numbers are written on the firewall. (See pics) Does anyone know what this means ? Thanks.
06-27-2015, 11:17 AM | #2 |
70+ ( Old Skool Club )
Re: What does 952 mean stamped on firewall ?
Are those numbers the last 3 digits in your serial number?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-27-2015, 11:53 AM | #3 |
The 952 stamped is the last 3 digits of your trucks PVI (Primary Vehicle Identifier) number.
The 952 written is the last 3 digits of your trucks General Assembly sequence number. Neither number has any real meaning. They were used to keep track of your truck, before and during the build. After the build is completed, those numbers don't have any real significance. Because both of your numbers are the same, it means that no shuffling occurred between body and paint, and was most likely built at the Fremont assembly plant in CA. Is the assembly plant code in your VIN number a Z? Here is a great thread on factory markings http://67-72chevytrucks.com/vboard/s...d.php?t=591402 And here is a thread if you want to decode your VIN http://67-72chevytrucks.com/vboard/s...d.php?t=570059
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 06-27-2015 at 12:17 PM. |
06-27-2015, 12:10 PM | #4 | ||
"I ain't nobody, dork."
All kinds of wonky numbers and markings on these cabs during the factory assembly line. Puts quite a cool touch to each rig.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-27-2015, 05:05 PM | #5 |
These numbers are not related to the VIN that I can see...its an Atlanta truck as far as I can tell. Its most likely a sequence of build type of numbering the factory used during assembly.... Its no big deal to me what they are, just wondered if anyone knew for sure. Thanks everyone for the input.
06-27-2015, 05:41 PM | #6 |
Just hadn't seen one from Atlanta.
The stamped number is the last 3 digits of your trucks PVI number. The written number is the last 3 digits of your trucks GA number. And your correct, they were used to track the vehicle throughout the assembly process. It's very cool to see a truck from Atlanta with the PVI number stamped on it. Thank you for posting it.
CHEVY/GMC VIN DECODERS |
06-27-2015, 10:54 PM | #7 |
I was going to say it means that it's made of almost pure silver, but then I remembered that would be 925!
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
06-28-2015, 10:19 AM | #8 | |
The full general assembly sequence number would be six digits, like "317952" and just the last three digits were written as a form of shorthand. Sometimes only the last two digits are written, ie "52". My truck just has "87". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-28-2015, 10:22 AM | #9 | |
The GA sequence number is counting up, one for every truck built. The VIN is counting up, but within it's own distinct "family", meaning counting up for every Chevrolet built, but counting up for every GMC built within it's own distinct sequence. In a plant that was also building Oldsmobile and Pontiac, like the passenger car side of Fremont, those would be counting up in their own distinct VIN sequence, too. K
