07-08-2015, 07:27 PM | #1 |
Tilt Steering to a NON tilt
So, here's the situation I'm in, my current tilt has.. a lot of play.. maybe an inch and half, i know you can tighten up the 3 toques, but, my ignition is also all ****ed, which could also be fixed. But my wheel doesn't lock any more, that mechanism is broke, the linkage that runs to the wiper switch is broke and some other spring in side right their. I can buy a rebuilt one for $520 on eBay, with a 1 year warranty, or do i just go to a non tilt? and what would that consist of? I keep my wheel all the way up as it is.
1985 High Sierra step side 4x4 |
07-09-2015, 09:09 AM | #2 |
Robert Olson Transport
Re: Tilt Steering to a NON tilt
swapping the columns is no big deal its like four bolts underneath the dash seven or eight on the fire wall and separating the upper and lower shafts, shift linkage and a couple of plugs. the thing you have to remember tho is that you need to get the correct column for the swap. make sure that its the same configuration with the wiring and that its the same kind of connection between the upper and lower shaft.. Some older trucks had a gear end on the lower shaft others had a D
07-10-2015, 09:06 AM | #3 |
Good source for rebuilt steering columns. Wayne is a good guy, too.
http://www.gmtiltsteeringcolumn.com/ A few months ago, I paid him $300 + $45 shipping for a very nice 79-83 tilt column. Mine even had a new shift bowl (the section the shift handle attaches to). Give him a call.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-11-2015, 03:36 PM | #4 | |
Home Built '87
x2
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
07-11-2015, 06:48 PM | #5 | |
Posted via Mobile Device |
Tags |
1985, column, steering, tilt |
