Old 08-04-2015, 08:43 PM   #1
bvb69C10
69 C10 cargo lamp
I took the cover off the cargo light of my recently purchased 1969 C10 to see what was wrong with the bulb and the bulb was missing. The local parts store doesn't have a part number for the light bulb. I was going to try an1156 which I believe is a back up light bulb but I thought I'd run it by the you all first. Anybody know the bulb part number?
bvb69C10 is offline   Reply With Quote
Old 08-04-2015, 08:49 PM   #2
72 K20
72 K20's Avatar
Re: 69 C10 cargo lamp
The bulb is a 2 contact bulb ( bottom looks like a 1157 ) that is a single filament. The 2 lower contacts are the hot and the ground . It doesn't ground through the side pins like most of this style bulbs . I will go out to the shop and see if I can find the package . I needed one for my K20 and they came in packs of 2.
I found it !!! 1004 is the number .
Hope this helps !!
Tom
72 K20 is offline   Reply With Quote
Old 08-04-2015, 09:00 PM   #3
bvb69C10
Hope this helps !!
Tom
Old 08-04-2015, 09:02 PM   #4
bvb69C10
Thanks a bunch for your help! I'll pick up one or two tomorrow.
Old 09-27-2015, 08:25 PM   #5
Benny-
Just wanted to second that 1004 is correct and that at least on a 72 c10 the cargo light only comes on when the door is open and switch is on.
Benny- is offline   Reply With Quote
Old 09-27-2015, 08:52 PM   #6
72 K20
72 K20's Avatar
That is if you have door switches ,,, not all of these trucks came with them. The dome light does have to be on tho.
