Old 08-19-2015, 05:20 PM   #1
angelobackwards
79 manual to power steering
I have a 79 short bed that I am going to be changing from manual to power steering. I have the gear box and pitman arm to do so was just wondering if I need an adapter plate? I have seen them for sale on CPP but was not sure if it is a must. TIA.
angelobackwards is offline   Reply With Quote
Old 08-20-2015, 10:30 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 79 manual to power steering
No, the box bolts on.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 08-20-2015, 02:34 PM   #3
angelobackwards
Okay thanks just making sure!
Old 08-20-2015, 06:37 PM   #4
truckin 79
Hey angelo what year box are you putting in? The reason I ask is because I have one from a 73 and now I think it might be the wrong power steering gear. Let me know how your install goes thanks
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 08-20-2015, 08:42 PM   #5
angelobackwards
I'm looking at a couple different options right now I have a buddy who has one off an 81 or 82 and also have a friend who has one off of an 85 suburban. I'm hoping to get to work as soon as i get home from vacation. I will let you know.
Old 09-05-2015, 02:27 PM   #6
J1MMY
Aren't all power steering boxes the same well into the '90's? I am using one from a'90 van which bolted right up and used the pitman for a '79. All a direct fit.
'63 C10 Longbox fleetside
'94 C1500 Sierra ex-USAF beater
J1MMY is offline   Reply With Quote
Old 09-09-2015, 07:23 PM   #7
truckin 79
got my steering box in finally and what a difference. The manual box was worn out with a inch slop in wheel. I have tamed the beast but steering wheel is canted still though with power steering pump. Do I just pull wheel off and place it back on? Good luck Angelo with mounting power steering pump
Old 09-09-2015, 07:26 PM   #8
angelobackwards
Hey sorry for the delay on this. I have had zero time to get any work done lately but I ended up selling the truck I was going to replace the gear box on and got a frame with one so little less work to do. Yours is lookin good though 79.
c10, chevy c-10, short bed, square body, steering
