Old 09-08-2015, 04:36 PM   #1
aod92
aod92's Avatar
Inline efi fuel pump location?
I installed my under bed tank and now I'm about to install my inline efi fuel pump. The fuel gets fed from the bottom back of the tank which is much lower than the fame rail where I want to mount the pump. Does my pump have to be gravity fed or will it be fine pulling the fuel up hill? Not sure if it's gonna be making my pump overwork?
aod92 is offline   Reply With Quote
Old 09-08-2015, 05:01 PM   #2
cooperhw
cooperhw's Avatar
Re: Inline efi fuel pump location?
I have a similar setup on my Chevelle. Comes out of the tank and immediately into pump hanging onto the side of my framerail. Then into a corvette pressure regulator/filter unit. Second line out the back of the regulator/filter goes back to the tank and the line out the front goes to the engine. 9000 miles so far, no trouble.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 09-08-2015, 05:03 PM   #3
aod92
aod92's Avatar
Does your line go uphill on the way to the pump?
Old 09-08-2015, 05:26 PM   #4
cleszkie
cleszkie's Avatar
You will probably starve the pump and burn it up eventually if it is located that far above the bottom of the tank. Now is the perfect time to install an in-tank pump while you have everthing exposed. An in-tank pump will run cooler, quieter, and much longer than a gravity fed external pump. Your EFI will than you with better performance as a result of consistent fuel pressure.
cleszkie is offline   Reply With Quote
Old 09-08-2015, 09:44 PM   #5
tsetsaf
We started with a similar setup and had fuel delivery issues from day one. Installed an in tank unit and immediately ran perfect. Much easier to do it right the first time. Also hard line and steel braid is your friend.
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 09-09-2015, 04:12 AM   #6
aod92
aod92's Avatar
Unfortunately I'm not gonna be able to use an intank pump. The tank I bought has no way to drop a pump into it. I'm gonna have to fab a bracket at the back of the tank right at the outlet so I can mount my pump there.
Old 09-09-2015, 09:54 AM   #7
cooperhw
cooperhw's Avatar
No, I guess it doesn't. It comes out of the fuel cell mounted in the truck and drops into the pump/filter.
Later,
Wayne
Old 09-09-2015, 10:10 AM   #8
bMr
You may not want to cut a hole in that gorgeous tank, but just in case... Aeromotive has a an in-tank pump for exactly this situation.
http://aeromotiveinc.com/phantom-fuel-system/
bMr is offline   Reply With Quote
Old 09-09-2015, 10:25 AM   #9
tsetsaf
We used this. Replaces the stock pickup and can be adjusted in height: http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm
In your picture it goes in where that gold plate is on the driver front of the tank
California Truck
Old 09-09-2015, 07:49 PM   #10
aod92
aod92's Avatar
The gold plate is actually the sending unit for the gas gauge. Can't put it there. If I use that style pump I'm gonna have to cut a hole in it.
Have any of you guys ever run your fuel lines down the drivers side frame rail?
Old 09-09-2015, 08:56 PM   #11
cleszkie
cleszkie's Avatar
Why so against cutting a hole in the top of the tank to drop in a fuel pump? I did it when I installed my Aeromotive in-tank pump. The kit comes with all the fittings and seals to make it look like a factory install, not a frankenstein hack job. Super easy to install, especially on a new tank that has not had any fuel in it yet like yours. It takes A-N fittings too on the outlets and return line inlet, so no hose barbs and hose clamps.
I understand it is pretty expensive (I paid something like $500 for my Aeromotive in-tank pump kit). But it was money well spent in my opinion because my fuel pressure is always rock solid and my fuel injection runs perfectly.
Old 09-09-2015, 09:41 PM   #12
aod92
aod92's Avatar
I'm really not against it I'm just not sure where the baffles are in the tank and I don't want to ruin a $500 tank by cutting a hole in the wrong spot. Plus I already bought a $300 Holley pump so I'm trying to make what I have work. I wish I would have bought the tank with the pump in it already but that's my mistake.
Old 09-10-2015, 09:07 AM   #13
tsetsaf
Exactly it is the sending unit. Very easy to fab the sending unit and attach it to the in tank pump. (you pop the tack welds on the sender and fuel float and attach them to the body on the new pump assembly).
No cutting required.
You could easily run the fuel line down the driver side.
California Truck
Old 09-10-2015, 09:10 AM   #14
tsetsaf
Basically your choices:
1. Mount the external pump on the bottom and back side of your gas tank = dangerous location. Risk starving and burning up pump + potential damage from road hazards.
2. Cut new hole in tank = requires cutting. Need to make sure you remove all debris.
3. Mount the unit I linked right in your sending unit hole = requires removing and attaching float level to the new pump assembly.
California Truck
Old 09-10-2015, 09:18 AM   #15
aod92
aod92's Avatar
Ok, I didn't realize you could still attach the float to that assembly. I'm gonna look into that for sure.
Thanks for all the help guys. I need to start doing some more research before I pull out my wallet and buy things!
Old 10-17-2015, 04:18 PM   #16
aod92
aod92's Avatar
Just bought the aeromotive set up. I'll post pics after its installed!
Old 10-17-2015, 04:33 PM   #17
Fitz
It isn't needed. The Holley Red and Black pumps are positive displacement pumps unlike the stock in-tank Corvette pumps. Mine is mounted on the frame rail, the pump lifts gas out of the top of the tank and has done so happily since I finished it in 2006.
Fitz is offline   Reply With Quote
Old 10-17-2015, 06:18 PM   #18
aod92
aod92's Avatar
Just installed it. Nice clean look and no pump on my rail.
