Old 09-27-2015, 10:55 PM   #1
74CustomK20
74CustomK20's Avatar
Question Squeeling Help?
Well guys for the longest time my k20 has squealed worse than a pig when it's running. It has a new water pump, that makes no noises when rotating by itself. Earlier today it was starting to rain while I was letting it idle so I figured hell I'll go ahead and undo the battery so I don't have to open the hood again, that way it won't get wet. And while running I undid it aND the squealing stopped... hooked back up and started doing it again. Thoughs? Opinions?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 09-28-2015, 12:00 AM   #2
chengny
chengny's Avatar
Re: Squeeling Help?
Tighten your alternator belt.
chengny is offline   Reply With Quote
Old 09-28-2015, 12:14 AM   #3
77 Big 10
77 Big 10's Avatar
Re: Squeeling Help?
It was only running the truck and not charging the battery, so it had less of a load. Like mentioned above, it could be a loose belt, could be a bearing.
Paul
77 Big 10 is offline   Reply With Quote
Old 09-28-2015, 01:12 AM   #4
74CustomK20
Re: Squeeling Help?
Will try the belt tomorrow morning, see what happens... I can also switch between a couple alternators... it just really made me wonder wtf lol
Big Nate
Old 09-28-2015, 09:57 AM   #5
riz
Re: Squeeling Help?
Make sure your pulleys are in alignment........ if they aren't the belt will squeal like a stuck pig and your belt with shred and fly apart over time.
I just did this to my K5 Blazer and it used to squeal all the time and now after removing 2 of the 3 washers it's all lined up and it doesn't make a sound.
That and check to see if your belt has no more than 1/8" deflection. Either way, replace your belt or at least inspect the one you're currently running.
RIZ
riz is offline   Reply With Quote
anal, charging, squealing
