10-04-2015, 03:56 PM | #1 |
Help identifying tubular A-arms and sway bar I just picked up
I just picked all of this stuff up from a buddy for a really good price, but I'm not sure who built them. I would really like to see pictures if anyone is using the same setup. The sway bar looks like it was added onto the lowers after they were built. They may be from the same manufacturer or not.. Any help would be appreciated. I'm going to strip them down to have them re-powder coated. The PC is horrible. Sprayed brake clean on them and it just destroys the PC. I'm not bashing anyone, but this is what gives PC a bad name, the PC wasn't cured long enough.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 10-04-2015 at 07:03 PM. |
10-04-2015, 03:57 PM | #2 |
Re: Help identifying tubular A-arms and sway bar I just picked up
Pic 2
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
10-04-2015, 04:04 PM | #3 |
DJM Suspension
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
10-04-2015, 07:02 PM | #4 |
Thank You. I would have never figured that out. Doesn't look like the sway bar came from them?
I just got them stripped down for new PC to match my frame.
10-04-2015, 07:08 PM | #5 |
Here is a pic of my frame
10-04-2015, 08:12 PM | #6 |
When I look at the end links I'm thinking Ridetech but I agree .. it looks like that lower bracket has been welded to the LCA (?)
I'm no pro .. I just noticed the silver and black looking powder coat on the control arms and thought JDM. My Pop had a 2008 Ranger we dropped with DJM stuff and it looked familiar Again, not sure on the sway bar but something says Ridetech. Is it solid or hollow?
10-04-2015, 08:13 PM | #7 |
The frame looks killer by the way. I wish mine looked like that
10-13-2015, 11:08 AM | #8 |
Thanks Chad, got them back from PC and installed. I ended up having to remove my 1.5" lowering springs and installing my stock springs to get the correct ride height. The truck handles so much better.
10-13-2015, 11:12 AM | #9 |
Forgot to add pic
10-13-2015, 01:26 PM | #10 |
Those won't work on your truck. They will only work on a truck that is painted white.
I will be over later today to pick them up and dispose of them for you. LOL!
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
10-13-2015, 04:12 PM | #11 |
Haha Brian, you definitely need to stop by soon. I'll take you for a ride..
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU Last edited by trkfrk; 10-14-2015 at 03:06 PM. |
10-13-2015, 07:14 PM | #12 |
its tough too see good but looking at your last pic it looks like you have your center link in backwards.
the inner tie rods should have the nut facing forward. its a easy mistake too make and it will make a world of differnce in your steering flipping the center link end too end. sweet control arms though.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
10-13-2015, 10:46 PM | #13 | |
10-14-2015, 08:12 AM | #14 |
i think it crazy that it fits just fine backwards.
but when you put in the right way it looks as if it wouldnt fit. the c link does come super close to the crossmember but it'll clear all the way. i think you have to install the center loosely then turn the wheels l&r to get the inners in. i did this before i knew any better on the kids 67 boy did it steer funky. your gonna crap yourself on the first ride it'll handle awesome.
10-14-2015, 08:28 PM | #15 |
My Carbon Footprint
You are aware those have a stepped spring pocket right? I had those on my truck, at least the 3" drop option. Truck rode like a Cadillac with them. They are not stock ride height.
10-15-2015, 11:06 AM | #16 |
I didnt at first. I initially installed my lowering springs and it was way to low and the tires rubbed the inner fender wells. Luckily I kept my stock springs and installed them and now rides like a Cadillac and gave me the stance I was after. Thanks to midnightblues, I turned my center link around too.
10-15-2015, 09:06 PM | #17 |
My Carbon Footprint
Nice stance!!
10-16-2015, 07:54 AM | #18 |
Your welcome just giving back some of the help I got from this site.
Awesome truck. Hope your alignment goes well
10-16-2015, 12:27 PM | #19 |
on your A arms, those will work with stock sway bar, which 99% of aftermarket don't. and the PO used a aftermarket sway bar anyway......nice build by the way!!!
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
