10-07-2015, 04:15 PM | #1 |
Kents 62 knock out knee knocker
I'm posting this for my pops. What started out as a "flip truck" and a "rat build" took a quick turn. Having fallen in love with these ugly trucks It wasn't as easy to let go of. He acquired the truck in a trade and decided to build it for a fast flip. He decided to fix the rust and 200 hours later it has all new everything.
1964 swb bbw body drop on 22s ls swapped c10 build.. http://67-72chevytrucks.com/vboard/s...d.php?t=617623 |
10-07-2015, 04:17 PM | #2 |
Re: Kents 62 knock out knee knocker
The frame matched the cab pretty well. It was pretty nasty so it was sent out for blasting and then base and cleared
10-07-2015, 04:19 PM | #3 |
It cleaned up a lot better than we thought
10-07-2015, 04:21 PM | #4 |
what rot was in the frame was removed and repaired. which you will see later was then removed later haha.
10-07-2015, 04:23 PM | #5 |
He based and cleared the frame it looks killer at this point haha
10-07-2015, 04:24 PM | #6 |
new drop spindles for the disc brakes
10-07-2015, 04:27 PM | #7 |
the stock dash was yanked and a 59 impala dash was then fitted into the truck. which looks like an easy fit.... well its not. But it is so worth the pain
10-07-2015, 04:29 PM | #8 |
More of the dash swap
10-07-2015, 04:31 PM | #9 |
The roof on the 62 had too many pin holes for his liking. lucky enough the roof that came on the bbw donor panel was rust free.
10-07-2015, 04:33 PM | #10 |
a girls gotta run, steer, and stop. so we fitted it with an LS.
10-07-2015, 04:36 PM | #11 |
broke out the tube bender and made a mount for the 49 chevy tank
10-07-2015, 04:38 PM | #12 |
The underside and the firewall were cleaned up
10-07-2015, 04:39 PM | #13 |
gas tank mounts removed and we reinforced the rear cab pan
10-07-2015, 04:41 PM | #14 |
now that the firewall was smoothed out and the bottom as well the fun starts
10-07-2015, 04:42 PM | #15 |
the bottom painted black and the cab got another coat of primer
10-07-2015, 04:44 PM | #16 |
The cab is ready.
10-07-2015, 04:45 PM | #17 |
Simple on the outside bright on the inside.
10-07-2015, 04:47 PM | #18 |
Lil man stopped by to help out B-Pa on his truck for a bit
10-07-2015, 04:57 PM | #19 |
a few more of the paint process
10-07-2015, 06:12 PM | #20 |
id like to see more of the Gas tank install!
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
10-07-2015, 10:21 PM | #21 |
WOW.. nice workmanship.. Nice booth... First time I've seen a dash replacement like that one
10-07-2015, 11:14 PM | #22 |
Great build. Subscribed
Wade |
10-08-2015, 01:11 AM | #23 |
I'm digging the direction your going with this truck , got a bbw 63 in the yard
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
10-08-2015, 10:07 AM | #24 |
What year is the frame? A 62 should've had the torsion bar front and "X frame"
And yours looks like a 63-66 frame Wade |
10-08-2015, 12:56 PM | #25 |
Ya we switched over to a 66 frame. the X is just too much of a pain in the ass.
I will grab a few more piks of the gas tank install here in a bit.
