Old 10-08-2015, 01:28 AM   #1
scrappy70
scrappy70's Avatar
Gas tank grommet
I just installed a new gas tank behind the seat and the grommet. I purchased the grommet from classic industries and it is smaller than the original. Has anyone else had the same issue and if so, where did you get the correct size?
scrappy70 is offline   Reply With Quote
Old 10-08-2015, 10:14 AM   #2
Lanman1972
Lanman1972's Avatar
Re: Gas tank grommet
The one I installed from Classic Ind. cracked after 6 months. I then bought one from GMC Paul that is guaranteed to not crack and leak. 2cents.
Lanman1972 is offline   Reply With Quote
Old 10-08-2015, 10:48 AM   #3
Sklptrljay
Sklptrljay's Avatar
There was a post just the other day about this. Gas tanks before 71' had a 2" neck and 71' and after had a 1 1/2" neck. I'd check that first.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 10-08-2015, 11:08 AM   #4
71swb4x4
71swb4x4's Avatar
Here you go, this thread had some good info
http://67-72chevytrucks.com/vboard/s...d.php?t=684432
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-09-2015, 12:48 AM   #5
scrappy70
scrappy70's Avatar
Thanks everyone. I will measure the filler neck tomorrow at the shop.
