10-09-2015, 08:20 PM | #1 |
Bedside fender brace hardware set up?
Can anyone confirm the bed brace hardware set-up for the fender side? The bed brace runs from the fender, front of tire, to a bed rail.
I believe it's one bolt, one washer and one nut. The bolt slides in from the inside, and there's just the nut on the outside. Edit...Incorrect. The restorations I've seen were wrong. Thank you......... It's the details. The correct assembly, working from the outside of fender in: 1. Bolt with integral washer (head faces down). Assembly reads "SCREW & WASHER ASM". 2. Fender 3. Fender brace 4. Lock washer 5. Nut
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-13-2015 at 01:40 AM. |
10-09-2015, 09:23 PM | #2 |
Re: Bedside fender brace hardware set up?
Subscribed
10-10-2015, 07:23 PM | #3 |
I B knowin someone B knowin this.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-11-2015, 07:55 PM | #4 |
Brace, correct hardware placement?
10-11-2015, 09:57 PM | #5 |
OK, I'll try...
I'm about 80% sure I reinstalled mine as they were installed new. Those that attach to the lower lip on the bed are head down then the bedside, washer and nut. Those that attach to the cross sills are head forward, then cross sill, washer and nut on the inside of the cross sill. However, I wouldn't be surprised if the bolts were installed pointed both ways by the humans working on the assembly line. If you are going to be that anal, be sure to use the correct original nuts and bolts. Oh, by the way, 32K is probably about right! Also, multiply the amount of time you expect it to take by 3! Jim Last edited by FirstOwner69; 10-11-2015 at 10:03 PM. |
10-11-2015, 10:04 PM | #6 |
The nut is on the outside of the fender on the few I've seen. I failed to confirm the washer set up.
The bolts to the bed rail have been an experience. I had a body bolt on one side, and a regular bolt and washer on the other, which was loose. I ordered a used set, and both were a regular bolt and washer. I was thinking the body bolt was correct.
10-11-2015, 11:26 PM | #7 |
I just went and actually looked at mine. First, there are no washers per se. All 4 bolts are the body type bolts with an integral/captured washer. They are 5/16" X 3/4". The lower bedside bolts are the ones I am almost 100% certain are installed as they came from GM. All 4 are, in fact, the original bolts and it wouldn't make sense to use bolts with integral washers if they weren't oriented with the washers against the sheet metal. Also, I installed load assist air bags in the rear coils when the truck was less than a year old and ran the valve stems vertically through that lip in the bedside just ahead of the bolts. If the head had been up, I'd have been constantly wondering if I was grabbing the bolt rather than the valve. Incidentally, today GM always has the bolts in a similar location installed head down.
I apologize for describing it incorrectly in my 1st post. Here's a pic of mine. |
10-13-2015, 12:09 AM | #8 |
Alright, I'm looking at my assembly manual. First off, you're correct. The bolts comes in from the outside. Meaning the few I've seen on restorations were wrong. I did find it odd the nut was on the outside. At any rate, according to this book, the correct assembly, working from the outside working in:
1. Bolt with integral washer (bolt head down). 2. Fender 3. Fender brace. 4. Lock washer or washer. I'm guessing a washer. Edit: Wrong.. it's supposed to be a lock washer 5. Nut As for the brace to rail........I suspect you're right, it's the same bolt.......That said, the bolts on my fender are about 1/8" shorter than the two sets I've seen for the rail. Couldn't tell you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-13-2015 at 01:28 AM. |
10-13-2015, 12:31 AM | #9 | |
10-13-2015, 01:23 AM | #10 |
I don't have a soft copy handy, but per the assembly, there should be a washer between the brace and nut. In fact, it's supposed be a lock washer. Just learned to read the manual (ha!)...... reads "L WASHER".
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-13-2015 at 01:29 AM. |
10-13-2015, 10:32 AM | #11 | |
I'm not trying to argue. I'm just stating the facts as they pertain to my specific truck. The bed was never touched except for a repaint by Chevrolet due to a paint adhesion problem. |
10-13-2015, 11:48 AM | #12 |
Wouldn't be the first time GM assembled a truck without all the hardware.
10-13-2015, 11:58 AM | #13 |
