Who does the best steering box rebuild?
I have done a ton of searching and most of everything I see says to get redheadsteeringgear to do it. I have a 67 manual steering box that has a ton of slop. I adjusted and its still bad and gets to tight in full lock turns so I know its gone to far. I hear to many horror stories of the parts stores rebuilds.
Anyone running a redhead rebuilt box? I am thinking about sending them mine.
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
Re: Who does the best steering box rebuild?
There has been a number of threads here with people saying Readhead steering gears are worth it, i wouldn't think twice about it.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I've got a Redhead on my truck, and I can't say enough good things about it's performance. Worth every penny.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
Did you buy a reman from them or send yours in. curious of turn around? I am sending mine in cause my truck is a Frankenstein and I have no idea whats in it.
I just installed a Redhead today, I purchased it due to the reviews I read online about them.
![]() Join Date: May 2012
I used a redhead, nice little company to deal with.
White K20 |
![]() Join Date: Feb 2009
So, I send them my steering box and I get back a gem? How much, approx.? They return it with a nice finish?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Nov 2006
my 71 manuel box needs remaning bad. I,ve taken up the play 2 times and its back to tons of sloppy play and getting hard to steer at slow mph
I BELIEVE IN JOHN 3:16 |
![]() Join Date: Apr 2011
I bought a rebuilt one from Auto zone in 09 it has worked perfectly less money for it and guaranteed for life.
Redhead gets my vote
yea I priced a reman box from oriellys , it was a a1 cardone unit, $168.00 exchange for a manuel box. p/s was 128.00 exh.
Moderator
![]() Join Date: May 2007
Same here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#13 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Don't the Redhead Steering Boxes have quicker steering ration so tighter steering and less lock to lock turns?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#14 |
![]() ![]() Join Date: Sep 2008
The 1977-1979 parts store boxes (Cardone) have the closer ratio. They are physically the same. The only problem I have run into is the size of the input shaft seems to be a crap shoot. I had to put a new rag joint on the last one, but, that's probably not a bad idea any way.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#15 |
I didn't look but it's probably a limited lifetime warranty. Same as a lot of their stuff. That means they'll replace it once at any time in it's life but then the warranty is done.
#16 |
The redhead does not offer a quicker ratio for my manual steering box and they strongly advise against it as it would make steering at slower speeds much harder. They do offer it for our trucks with power steering though. I will be shipping mine out to them monday. Thanks guys for all the input.
#17 |
interesting on the 77-79 quicker ratio, thanks
#18 |
Any of the suggestions above will work fine.
I use these people when I have one rebuilt. http://www.powersteering.com/us/
#19 |
laying low
![]() Join Date: Mar 2001
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#20 |
+1 for redhead. Used them many times. I never had one redone by them though. It was always exchange for me.
70 lwb c-10 |
#21 |
I put a red head on my 71 and sent them my leaky one for the core. No problems so far they did not recommend the quick ratio for my power steering
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#22 |
I just rebuild my own
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#23 |
Well Redhead has my vote. Basically I ordered the wrong one tues called Wed. To make sure I was getting the right one. They said no and changed my order. Received it yesterday and all I can say is wow. I can't believe how bad my other was. Made me realize how unsafe it was. I rebuilt my complete front end a week before and this was the last piece to the puzzle. Everything is as tight as new now. I recommend redhead to anyone.
P.s. If you have a manual box that looks like their very first picture on their inventory page don't order it for your truck. It actually fits on the inside rail. Not the outside like our trucks even though it's identical minus the output would be upside down . Call them.
#24 |
+1 on the rebuild. Cost me $30 for a PS unit and some time on YouTube watching the videos. Pretty easy.
