![]() Join Date: Sep 2011
63-66 Fleetside Rear Bumper With Brackets
Original rear bumper . The bumper is in pretty good used shape but does have a very slight twist toward the RH passenger side. I tried to take a picture of that area. Only one extra hole and that is at the very bottom of the bumper. One very small dent just above the hole mentioned. It is very small and would press out easily. The brackets are in good used shape. The filler pans are in poor condition. It might be easiest to buy a set of repos unless you have a lot of time for straightening. Depends on you build. This would be a good bumper for a driver type truck or an easy chrome as it would be a very good core to start with. $150 plus shipping. Shipping will run between $60 and $75 depending on your location.
I will have to remove the brackets before shipping . I will probably not be able to save the bolts. |
Re: 63-66 Fleetside Rear Bumper With Brackets
More pics
Bumper has been sold. Thanks
