![]() Join Date: Jun 2014
Rear End Gear Oil
Re: Rear End Gear Oil
I like the royal purple stuff there is no need for a posi sadditive with the royal pyrple
#3 | |
"Eaton Posi units perform best when using GL4 (or better) mineral/petroleum based gear oil. A four ounce bottle of friction additive/modifier is also necessary for optimum performance." In short, do not use synthetics. They increase the clutch wear. |
#4 | |
It's just the posi manufacturer. There were other manufacturers of posi units as well.
#6 | ||
Is there a friction additive/modifier you guys would recommend? |
GM used to have a posi additive I would imagine they still do
Sure. Either, both and many other brands available from your local auto parts store or Summit Racing!
Moderator
![]() Join Date: Dec 2012
Yep, no syn with an Eaton. Good 80w90 and a bottle or two of the GM posi additive.
#11 | |
Six in a row makes it go...
![]() Join Date: Mar 2009
Interested to see where this conversation goes.
Whatever you end up using, I would make sure it is API GL-5 rated.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#13 | |
OBTW if you check the tech support on the Eaton website they do say that synthetic oils dissolve the clutch material in their PosiTrac units shortening the life of the clutch pac. Please note that the friction additive GM recommends is the AC Delco part number 10-4003. |
#14 |
Why did gm put mobil one synthetic gear oul in from the factory answer that question instead of avoiding the issue
#15 |
![]() Join Date: May 2003
Here's a link to Eatons owners manual, page 25 covers the lub specs. It does list either can be used.
Not sure if this applys to a 40+ yr old unit ? http://www.eaton.com/ecm/idcplg?IdcS...me=PCT_1087652
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#16 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Mobil One was first introduced in 1974 so why do you think it was factory supplied in our 67-72 trucks?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#17 |
LEARN HOW TO REad as I never said it was in 67-72 chevy trucks// I had a 96 chevy with an eaton posi from the factory and it came from the factory with mobil one synthetic oil
#18 |
Florida Edition
So why did you post this on the 67-72 forum, did you think the OP was talking about a late model truck?
#19 |
For your 1996, GM DOES recommend synthetic oil for your differential. And, that differential does use an Eaton limited Slip center section. Your problem is you thought you had a clutche Eaton Posi unit but it is, in fact an Eaton TrueTrac which uses planetary gears not a clutch pack.
#20 | ||
"I ain't nobody, dork."
LMAO...
![]() ![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#21 |
20' Daredevil (Ret)
#22 |
fact of the matter is that synthetic oil is far superior and causes no long term problems when used in a posi or locker of any type
back to the horsecrap statement that you can't use synthetic
#23 | |
I had my rear end rebuilt and added an Eaton posi. The shop included a bottle of the yukon additive, and said to just use regular gear oil, not synthetic. They didn't say why no synthetic, but now that makes sense. Thanks |
#24 | |
Moderator
Just make sure it's not synthetic horsecrap, and you'll be ok. |
#25 | |
Moderator
