Old 10-15-2015, 08:48 PM   #1
68chevystepside
68chevystepside's Avatar
Arrow Computer Controlled Distributor To H.E.I.
I know that the distributor gears changed on the computer controlled distributor. I have a 350 from an 89 G30 that i am changing from tbi to carb, is there an oem HEI distributor that i can use for this engine?
68chevystepside is offline   Reply With Quote
Old 10-16-2015, 07:16 AM   #2
hugger6933
Re: Computer Controlled Distributor To H.E.I.
Any of them should work even the spark controlled ones if you hook the black and white wire together to bypass the spark knock thingy, or change out the module for an earlier one. Why would the dist gear be different? The 89TBI motors didn't have a roller cam, none of the TBI motors did.
hugger6933 is offline   Reply With Quote
