Old 10-16-2015, 04:01 PM   #1
6768chevylover
6768chevylover's Avatar
frame swap
I own a 67 2wd short bed pickup and am looking into buying a 71 blazer 4wd. I was planning on just restoring the blazer but then started thinking, could i swap the the truck to 4wd and the blazer to 2wd? im sure i know the answer just wanted to pick some brains. thanks
6768chevylover is offline   Reply With Quote
Old 10-16-2015, 04:36 PM   #2
Hutch
Hutch's Avatar
Re: frame swap
6768chevylove
One Small Issue is:
The frame length and coil spring Suspension versus Leaf Spring's
Short bed frame= 115"
Blazer Frame = 105'
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 10-16-2015, 04:40 PM   #3
CarterD2015
CarterD2015's Avatar
Re: frame swap
Instead of swapping the frames could you change out the front crossmember and rear suspension? That way the vin (partial I think) stamped into the frame would remain with the correct vehicle.
Dennis
37 ford coupe
68 short narrow
72 short wide
CarterD2015 is offline   Reply With Quote
Old 10-16-2015, 11:33 PM   #4
Hutch
Hutch's Avatar
Re: frame swap
Anything can be done if you know how to fabricate
Welding spring perch's and shock mounts etc.
It is not a direct swap from a blazer to a truck
I once had a chance to take measurement's on a 4x4 short frame and a 2 wheel short frame
Both were bare frames and side by side
The 4x4 front is similar to the 2 wheel front
However
The back of the 4x4 is totally different from the 2 wheeler
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
