Old 09-14-2003, 04:05 PM   #1
Locutus
Locutus's Avatar
Put the board to use-Brake Problem 89 Sub
The brake warning light keeps coming on in my 89 Sub. We recently redid the brakes front and back. I checked for air in the lines and rebleed them, there was no air in the lines and the MC is full on both chambers. The light will go out if you stomp on the brakes while sitting still, but it comes back on when you stop suddenly or press hard on the pedal. Any ideas?
Mike
Locutus is offline   Reply With Quote
Old 09-15-2003, 01:30 AM   #2
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
you SURE you got the air out of the lines? You can always disconnect that little connector @ the proportioning valve. Maybe the valve and/or sensor is bad
mike
mike reeh is offline   Reply With Quote
Old 09-19-2003, 02:46 PM   #3
Krosati
You still have air in the lines. You may need to bleed the MC before doing the lines. You also may have your rear adjusters out of wack. Tighten them up a bit and check it again.
Krosati is offline   Reply With Quote
Old 09-19-2003, 04:06 PM   #4
Locutus
Locutus's Avatar
There is no way to adjust them there are no holes on the backing plates of the rear brakes.
Old 09-19-2003, 09:40 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
some vehicles have the adjuster access right on the front of the drum
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 09-20-2003, 11:19 AM   #6
Krosati
If you don't want to knock out the plugs on the face of the drums, you cam manually adjust them until you can just slide the drums on. After everthing id assembed, drive the sub in reverse (5-6 mph) and firmly apply the brakes. This is how the adjusters work anyway. Get in the habit of using your brakes when you back up rathe rather than shifting to neutral then drive.
Old 09-20-2003, 06:21 PM   #7
Locutus
Locutus's Avatar
I always apply the brakes going into reverse and before shifting into drive. I think it would be fool hardy to do otherwise. When I replaced the rear brakes we did adjust them till the drums just slid on and I put in reverse and applied the brakes several times till I felt secure that the rear brakes were catching.
