Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 11-13-2015, 11:18 PM   #1
mrf1002u
WTB 54-55 1st Bellhousing crossmember
Wanting to buy a 54 or early 55 crossmember for under the engine/bellhousing. 250 swap planned and I want to keep the sm420. Been told that is the right animal for the job.
Larry W.
mrf1002u is offline   Reply With Quote
Old 11-15-2015, 09:48 PM   #2
MidLifer
MidLifer's Avatar
Re: WTB 54-55 1st Bellhousing crossmember
Did they differ in 54-55 from the other AD years? I did a T5 swap in my 50 and may still have the crossmember laying around. Should I go up to my parts loft and look or were they different?
MidLifer is offline   Reply With Quote
Old 11-15-2015, 11:56 PM   #3
mrf1002u
Midlifer,
The way I understand it, the 54 and early 55 are unique, although the 60's look similar, they must be different in shape and or width.
Here is a pic of a 50 3600 crossmember... compare it to the 54 I posted before. Please note that the picured bellhousing and crossmember do not go together. The bellhousing goes to the very first pic in this post and further down where they are shown together again. Sorry for the confusion.
I have seen pics of one modified, but it was heavily modified, I'd rather avoid that. The 54-55.1 is made to work with this bellhousing, which will bolt to a 230, 250, 292, and newer V-8's.
Someone correct me if any of this is wrong, please.
If you still have yours, I may be interested. Can you get a pic?
Thanks,
Larry W.
Last edited by mrf1002u; 11-17-2015 at 03:32 PM. Reason: Clarity. Pictures are confusing people.
Old 11-16-2015, 12:25 AM   #4
mrf1002u
Midlifer,
Sorry I read your post wrong. From what I know, your 50 would look like my 53, not the first one I posted from a 54.
Old 11-17-2015, 09:08 AM   #5
youngrodder
youngrodder's Avatar
Originally Posted by mrf1002u View Post
Midlifer,
I think I have one of these that I tore off my 53 Suburban. I will take a picture of what mine looks like. I'm in MI so shipping might not be the cheapest.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-17-2015, 09:34 AM   #6
mrf1002u
Marc
By all means, snap a pic. I have relatives in Ohio. That would help.
Thanks.
Old 11-17-2015, 12:39 PM   #7
youngrodder
Thanks.
OK, I will try to grab one at lunch.
Marc
Old 11-17-2015, 02:22 PM   #8
youngrodder
Here are some pics
Other than a thick coating of grease and dirt it is in good shape. There is no rust through or rot. I was careful not to mangle this when I took it out.
Marc
Old 11-17-2015, 02:42 PM   #9
MidLifer
MidLifer's Avatar
OK well my crossmember is definitely the earlier type. Good luck with the hunt for a later one.
Old 11-17-2015, 03:18 PM   #10
mrf1002u
Here are some pics
Marc
Marc,
Thanks for going to the trouble...unfortunately, that will be just like the one in my 53 too. The one needed will look similar, but the holes are like the first pic in this post. I really did this wrong, I shouldn't have posted the wrong crossmember pic in the same post as the right bellhousing, especially since they look like they belong together.
Larry W.
Old 11-17-2015, 03:19 PM   #11
mrf1002u
Really appreciate the effort.
Larry W.
Old 11-17-2015, 03:28 PM   #12
mrf1002u
Larry W.
Hoping I do not make things worse........but here is the right bellhousing and the right crossmember from a 1954 to early 1955 truck, together.
The angled feet of the bellhousing fit on rubber mounts that go into the larger holes on the crossmember. The 53 down crossmember doesn't have the right holes in it and I assume has a different shape or drop to it.
Thanks,
Larry W.
Old 12-02-2015, 11:18 AM   #13
mrf1002u
Old 12-15-2015, 12:35 PM   #14
mrf1002u
FOUND THANKS Re: WTB 54-55 1st Bellhousing crossmember.
Thanks,
Found one.
Larry W.
216, 250, crossmember swap, sm420, swap
