Old 12-14-2015, 06:30 PM   #1
elks
Heater System Upgrades....
For years my system has seemed a little weak and barely able to keep frost off wundows etc. The heater core finally started leaking and is going to need replaced.
While I am in there I want to do all I can to make the blazer warmer for my winter hunting etc. So is there a good existing thread? Or atleast a list of thing to fix and repair?
It is a 1972 Blazer without A/C.
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 12-14-2015, 09:12 PM   #2
cleszkie
cleszkie's Avatar
Re: Heater System Upgrades....
Chances are that heater core had some buildup in it too. A new heater core with good coolant flow should give a little more heat. You might also consider going to a hotter thermostat. In the winter, this will allow the water temps to get higher before the thermostat begins to open. The result is hotter water in the heater core and more heat. Other than that, I would suggest some insulation of some sort on the floors, in the doors, and on the inside of the bed sides to keep the heat in and cold out.
cleszkie is offline   Reply With Quote
Old 12-21-2015, 10:04 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's a link to the pic's I took while rebuilding my a/c system. I tore apart everything and rebuilt it all including the air box.
Take a look. Maybe the pics will help.
http://public.fotki.com/blazbk/blaze...d_of_ac_syste/
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-22-2015, 12:42 AM   #4
themb2g
I took my heater out and replaced it with a vintage air. It worked well when I pulled it out a few years ago, if you pay for shipping its yours
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 12-26-2015, 05:54 PM   #5
dennis7222
dennis7222's Avatar
In my 72 Blazer, I put a blower motor out of a truck that had air conditioning. Now it blows my brains out !
dennis7222 is offline   Reply With Quote
Old 12-27-2015, 10:30 PM   #6
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Are they the same size and fitment or did you have to customize the fan? Any noticeable differences between standard blazer fan Vs. A/C fan?
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 12-28-2015, 05:11 PM   #7
dennis7222
dennis7222's Avatar
YEP, they are exactly the same, all you have to do is swap them out, but I think that I had to take the fender well out to get to it.
Old 01-26-2016, 09:11 PM   #8
Sacramento70
Blazer Fanatic
Nice...its it your opinion that the A/C motor blows harder because its an A/C motor fan or is it just that the fan motor you put in was a bit newer and in better shape?
1970 Chevy blazer
Old 01-26-2016, 09:23 PM   #9
cleszkie
cleszkie's Avatar
A fan that blows more air won't solve an air temperature problem. It will just blow more cool air.
Old 01-27-2016, 11:12 AM   #10
pound41
Most blazer I have been in with a new core in them will run you out of the front seats problem always has been pushing the air to the back
pound41 is offline   Reply With Quote
