12-17-2015, 02:58 PM | #1 |
1971/72 gas pedal Assembly
Does any company sell a stock style gas pedal assembly for 1971/72 trucks. I like the cable assembly compared to the rods and linkages. Thanks
Posted via Mobile Device |
12-17-2015, 03:34 PM | #2 |
Re: 1971/72 gas pedal Assembly
The mounting between the two pedals (67-70 rod) (71-72 cable) is different. There was a board member that made an adapter plate that I owned at one time, but I sold it off a while back, and he no longer is an active member here.
Lokar makes a billet assembly in both polished, and black for both assembly styles that uses a cable. They are the only ones I know of that makes a bolt-in kit for this. Otherwise, you'd have to go to a junkyard and pull a pedal assembly from any 71-87 truck, or van (the mounting is all the same, just a different plastic pedal on the trucks) and fab your own bolting system. hope that helps! |
12-18-2015, 10:25 AM | #3 |
My advise and what I did was to get a complete assembly off the board and convert. There is a thread on the board that provides a very simple conversion method that does not require an adapter. If memory serves me right it's titled no drill conversion. Good luck
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
12-18-2015, 10:59 AM | #4 |
Thank you for the Replys. I will look into the conversion. I might be able to find the whole setup locally.
12-18-2015, 11:53 AM | #5 |
Old member
Lokar has a nice gas pedal assembly. They have one all billet are black billet to match the brake and clutch are you can buy the whole set.
http://www.ebay.com/itm/Lokar-XBAG-6...lVfycV&vxp=mtr
12-18-2015, 02:26 PM | #6 |
I just installed the Lokar one a couple weeks ago. Very nice quality. I got it from Jegs.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
