12-17-2015, 05:04 PM | #1 |
Can you identify these
Howdy folks
What are the armrests mounted on my 67 C10 ? The one on the drivers door does not match my interior. Passenger side is close in color. If I could figure out what they came off of, I would buy one for drivers door. They are mounted with 3 screws . I think the stock armrests are only mounted with 2 screws. Thanks for any help. [IMG][/IMG] |
12-17-2015, 05:21 PM | #2 |
Re: Can you identify these
The '67s had a unique, '67-Only, armrest. Some vendors sell this piece,
it's different from the chunkier '68-'71 armrest. Behind the door panel, on the door inside are some weld nuts for the armrest bolts to connect to. Remove the door panel after pulling the 2 handles off. You have to drill thru the door panel to make holes to connect the armrest to the assembled door. I have a junkyard armrest of unknown origin on my drivers side door. It must have been a GM donor because the bolt holes lined up. I found it in the mud and gave a dollar for it. Never found match for the passenger side. Possibly yours are similar junkyard finds from who knows what.
12-17-2015, 05:37 PM | #3 |
I don't want to drill more holes in door panel. If the stock armrests would line up with 2 of the holes I would buy a set.
The 2 farthest screws spacing is 9 3/4 " Anybody know what the spacing is on the factory armrest? |
12-17-2015, 05:40 PM | #4 |
Should be able to pick ups some vinyl die paint and just freshen them up to the same color.
12-18-2015, 06:30 AM | #5 |
OH NO ! SACRILEGE ! Those are 1968-72 FORD door handles !!! Oh the HORROR !
http://www.ebay.com/itm/like/2521903...chn=ps&lpid=82 |
12-18-2015, 08:55 AM | #6 |
The stock arm rest holes are closer to 6 inches I believe. I measured mine a while back. That may not be exact but I know it wasn't 9 3/4"
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
12-18-2015, 10:29 PM | #7 | |
Thanks Grumpy Now I have to decide if I want to sell it!! |
12-18-2015, 10:34 PM | #8 |
12-18-2015, 10:35 PM | #9 | |
Thanks Now what color.....black or blue? Last edited by Stoli; 12-18-2015 at 10:44 PM. |
12-18-2015, 10:43 PM | #10 | |
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
