Old member
Last weekend while doing our local Toys for Tots I had the B&M shifter cable to break on me. I was able to put it in gear by hand after crawling under it and grabbing it with a pier of pliers. This is the second B&M 5' cable to break in about 10 years on me so I figured it was time to change it.
So I ordered a 8' B&M shifter cable and installed it today. The shifter is way better. It shifts a lot easier,smoother and has way less bend in it. I'm very pleased. If you have to buy a cable get the 8' and make life a lot better. Oh I ordered it through O-Reilly's and got it in 2 days. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
