01-07-2016, 12:46 PM | #1 |
Champion radiator mc369 4 core
Why do they sell these? Fits great side to side but they are too tall!!!!!
Fwiw the 4 core saddles work. Sorta????
1967 C10 SWB Owner - Rustbelt Restorations |
01-07-2016, 01:11 PM | #2 |
Re: Champion radiator mc369 4 core
Any room to work with on the bottom? You don't need much, even just 1/2" to get the top saddles to likely bite enough to clamp down.
01-07-2016, 01:17 PM | #3 |
Even if I shave the rubbers it won't work....the aluminum tank/welds end up rubbing on the metal retainers defeating the need for the rubbers.....
01-07-2016, 03:28 PM | #4 |
I ran into a similar problem with my 'Spectra' radiator. A suggestion was made to cut a piece of garden hose to use in place of the rubber grommits. I saved my grommits & cut a section of an old bicycle tube, folded it over & set it into the brackets. The radiator still rode high but at least it was held in place. The upper mounts were also high. I put several washers under the upper mounts where it mounts to the frame. The other item affected was the shroud because the radiator was riding higher, I had to make 2 small plates about an 3/4 inch wide by one inch long and put a hole in each end. I mounted the top hole to the frame and bolted the shroud on to the lower hole which allowed the shroud to ride in it's original position. Not a great solution but it was the best I could do.
01-07-2016, 07:38 PM | #5 | |
This was purchased to correct the same problem I had with my Spectra copper/brass 4 core.........2 different trucks same issue....... And I DO NOT want spacers, just a 4 core that fits !!
01-07-2016, 07:55 PM | #6 |
Man, That's one mistake I didn't make (Ive made many on my build--but at the last minute I decided not to buy one of these)
Is there any interference with the hood? If its just too tall and doesn't hit anything a new set of brackets could be fabbed. (something else to do!!)
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
01-07-2016, 09:34 PM | #7 |
I have a Champion in my truck and it fit pretty decent. I did shave just a little off the rubber pieces but it was closer than yours looks to be. I don't remember the part# on mine
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
