Old 01-07-2016, 06:59 PM   #1
cruisinthe34
cruisinthe34's Avatar
'Morning Glory' 1971 C10 Stepside
Well, we're off.......
Acquired the title last Wednesday 12.30.2015 and got the truck home yesterday at noon, 01.06.2016
Very BASIC Truck:
So far I have ordered:
1.) Holley 390 Carburetor
2.) Clifford 6=8 Intake and split exhaust headers
3.) Power Steering Conversion kit CPP
4.) 4/6 Drop Kit ECE
5.) Power brake Booster ECE
6.) 700R4 kit Monster Transmission
Still need to order:
1.) Gas tank relocation kit
2.) Rocker panels
3.) Bed wood and strips
4.) Door Lowers
5.) Possibly Cab Corners
6.) 18 or 20"" Wheels and tires.
etc.....etc.......etc...
Hopefully soon she'll be all gussied up:
Steve
My Build Thread: http://67-72chevytrucks.com/vboard/s...=morning+glory
1971 C10 Inline 6 250 700R4 "Marlene"
1934 Chevrolet Master Sedan 350 700R4 "Iris"
1941 Ford 1/2 Ton 5.0 H.O Roller C-4 "Rose"
2019 Honda Ridgeline
cruisinthe34 is offline   Reply With Quote
Old 01-07-2016, 08:32 PM   #2
DeepOceanStepside
DeepOceanStepside's Avatar
Re: 'Morning Glory' 1971 C10 Stepside
very cool i will defiantly be following this build!
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 01-11-2016, 06:06 AM   #3
cruisinthe34
Alright, I didn't get much done this weekend due to a minor leg injury, but I DID get the truck moved over closer to the working garage. I noticed a few things I had subconsciously planned on but now they are FOR SURE.
New Wiring harness and complete instrumentation package.
Since it is a basic TRUCK, there's Speedo, Fuel, and idiot lights. I had thought I would be re wiring the truck in my original plan since I intend to add A/C etc. I am accustomed to having the full gauge package, water, fuel, volts, speed, tach etc. So looks like I'll be sourcing new gauges too.
I'll order a new Ron Francis wiring kit this morning......
Steve
Old 01-12-2016, 09:47 AM   #4
Katrina/10
Katrina/10's Avatar
I like it.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-13-2016, 08:46 AM   #5
cruisinthe34
Things sure tend to daisy chain when I start one of these projects. Planned to rewire the whole truck, so ordered the Ron Francis wiring kit, which forced me to examine the Alternator and will change from external regulator to Internal. Moving from 3-speed column shift to 700R4 floor shift causes removing original column to ordering an Ididit column. Going to HEI with internal coil.
Today is a big day, I'm actually moving the truck in to my working garage where I have a lift and can soon actually start spinning some wrenches. Most parts are ordered, some are already here. Should have a couple months of winter to attack the mechanical/electrical aspects of this build. I'll start adding photos as I get started in the garage today.
Steve
Old 01-13-2016, 03:54 PM   #6
cruisinthe34
Parts are still arriving at a furious rate. Today is a HUGE day, got Morning Glory settled in to her new Winter home on the lift.
Steve
Old 01-13-2016, 09:09 PM   #7
cooperhw
cooperhw's Avatar
Right on truck. I am also doing a short bed step side. 68 model.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-14-2016, 01:09 PM   #8
cruisinthe34
Well, since I'm rewiring the whole truck, I had choices of which way to go at the instrument panel. Mine, being a basic "TRUCK" only has the three hole bezel, 5" Speedo, 3 3/8" blank and a 5" fuel gauge.
Just ordered these little babies (Speedo I ordered doesn't have the tach included, it will be separate)
For the center hole I ordered a 3 3/8 Tach:
Steve
Old 01-18-2016, 05:16 AM   #9
cruisinthe34
Getting started. First attacking the 'Helper or overload springs.....
Getting it cleaned up and prepped, then the ECE 6" drop in the rear.
Steve
Old 01-18-2016, 11:31 AM   #10
68Gold/white
Even though it's basically a stripper, being a 71, you've got disc brakes!!!
All you will have to do is maintain it , not all the swapping headaches to get it converted!!
68Gold/white is offline   Reply With Quote
Old 01-18-2016, 02:20 PM   #11
cruisinthe34
yeah..... thats a GOOD thing. However, I am adding POWER to the disc brakes and POWER steering. Also, going to a 700R4 from the 3 on the tree.
Steve
Old 01-31-2016, 12:20 PM   #12
cruisinthe34
Well, today was going to be a big "Get Started" Day for the '71. Parts accumulation has been going well......Lower front 4" and rear 6", install 700R4 with floor shift, Power brakes, power steering, rewire the truck, install Clifford intake Holley 390 carb and Clifford headers.....
I was going to turn the truck around on the lift in the working garage, but there is still a 3" sheet of ice in front of the working garage from last weeks, snow event, so I cant move it til later this week.
Steve
Old 01-31-2016, 01:42 PM   #13
'68 Newtricks
'68 Newtricks's Avatar
interesting it has an overload leaf, on a short bed 1/2 ton
nice truck
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-01-2016, 04:55 AM   #14
cruisinthe34
Yeah, not sure that was factory, I recognize no reference to it on the SPID
Steve
Old 02-01-2016, 09:46 AM   #15
68Gold/white
nice truck
I have seen a factory overload, the leaf contacted a pad behind where the axle bolts to the control arm, there was a rubber pad/snubber where it made comtact.
I have also seen what I think was an aftermarket add on leaf, it had a rubber pad on the end of the leaf and contacted the top of the axle tube, factory set up looked like the better way to go....
Old 02-01-2016, 11:03 AM   #16
steelhorse
steelhorse's Avatar
I think I will follow this on. Nice to see a more original build every once in a while.
steelhorse is offline   Reply With Quote
Old 02-02-2016, 08:21 AM   #17
cruisinthe34
Got home Monday and turned her around...... Ron Francis wiring kit also arrived Monday evening.
Almost ready to start dis assembly. Wiring, Power steering and 700R4 with floor mount shifter and new Ididit column...... all sort of intertwined seems the best starting point.
Steve
Old 02-11-2016, 08:15 AM   #18
cruisinthe34
Fresh built 700R4 finally arrived....
Steve
Old 02-12-2016, 01:00 AM   #19
Dustmaker65
Dustmaker65's Avatar
Looks to be a great start!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 02-15-2016, 02:20 AM   #20
jeh
jeh's Avatar
Hey Steve, looks like your off to a good start, I'm just up the road from you. Well, about 70 miles!!! It's nice to see some guys on here from WV
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 02-15-2016, 03:26 AM   #21
swamp rat
swamp rat's Avatar
Sub'ed
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-15-2016, 09:22 AM   #22
Green67Stepper
Green67Stepper's Avatar
exited to see the progress on this one. you got alot of parts built up!
Love that factory color too.
Green67Stepper is offline   Reply With Quote
Old 03-05-2016, 09:57 AM   #23
cruisinthe34
Well....
Steve
Old 03-05-2016, 10:06 AM   #24
cruisinthe34
Well..... Pulled the radiator out and decided to mock up the new accessory Brackets....
Steve
Old 03-05-2016, 10:09 AM   #25
cruisinthe34
Here's a closeup of the power steering pump/bracket/resevoir....
Steve
