Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-12-2016, 05:31 PM   #1
53 randy
Question radio presets
I have a retrosound ZUMA radio in my 53 3100 and i am putting in a battery disconnect, how can I keep my presets in the radio. I will have it disconnected for some time. Some one suggested that a buy a computer saver from FLAPS but they are only go for about a day maybe two. I thought I could put a fused by pass from the battery to ground. The radio as two power wires one consent ON and one key ON. With the key OFF it only draws 3.5 Mill amps and I think that's for the presets. What size fuse do I need and will it work? I am thinking 2.5 or 5 amp. Randy
53 randy is offline   Reply With Quote
Old 02-12-2016, 07:30 PM   #2
68is4me
68is4me's Avatar
Re: radio presets
I am not no electrical expert, but why are you putting in battery disconnect? I think that 3.5 millamp is to much draw for just a radio memory. Are you sure you don't have a draw somewhere else.
Other wise I was thinking you could run a power wire to the live side of the disconnect just to the radio, but that would be silly if you are trying to keep the battery from going dead.
68 c10 swb stepper
68 c10 swb stepper
67 c10 lwb
06 gmc duramax
68is4me is offline   Reply With Quote
Old 02-13-2016, 01:15 PM   #3
_Ogre
_Ogre's Avatar
Re: radio presets
presets??? who uses radio anymore????
though i do hate resetting the clock everytime
if you have the disconnect to keep the battery from going dead for long term storage, any bypass will kill the battery over time
if the disconnect is for theft/security reasons... read on
with the disconnect on the ground cable a fused ground bypass will work, but you will get tired of changing fuses when you turn the key, forgetting to turn on the disconnect
install the disconnect in the positive cable and run a fused bypass to constant on wire to the battery
my 58 truk has an alarm system on it, i use no disconnect but have to put a battery tender on if i don't drive the truck every 7 days
shop air compressor timer
Old 02-13-2016, 02:24 PM   #4
53 randy
Re: radio presets
No, I am putting the disconnect in because it a pain the take the terminal off the battery when I work behind the dash. I use a battery tender to keep the battery up and when I disconnect it I also turn off the tender. I am going to put the bypass in the neg. side with a 5 amp fuse. thanks _ogre and 68is4me Randy
Old 02-13-2016, 05:40 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: radio presets
This is what I would use. It's simple and cheap. For short term use it would be perfect.
Amazon.com: 12V Automotive Settings Keeper w/9V... Amazon.com: 12V Automotive Settings Keeper w/9V...
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
