Old 03-03-2016, 01:26 PM   #1
NewMexCrew
NewMexCrew's Avatar
83 12v Cummins swap sputtering under load
HELP!! I currently have a 1990 GMC Crew Cab with an 83 12v Cummins in it. I am new to the Cummins engines. Recently the truck started sputtering under load like if it is starving for fuel. Truck starts fine and runs fine around town but while towing or going up hill at highway speeds under load it starts to sputter like its running out of fuel. If I back off the throttle it gets a little better. Any ideas on what could be wrong? Could it be the lift pump? I recently changed the fuel filter and air cleaner. Any help would be greatly appreciated.
NewMexCrew is offline   Reply With Quote
Old 03-07-2016, 11:42 AM   #2
NewMexCrew
NewMexCrew's Avatar
Re: 83 12v Cummins swap sputtering under load
Anybody?? If this is the wrong location for this please let me know.
Old 03-07-2016, 12:37 PM   #3
usetheBFH
usetheBFH's Avatar
Could Definitely be the lift pump. I HIGHLY recommend getting an in-cab fuel pressure gauge. That way you can watch the line pressure. I have had about a half dozen lift pump failures on 12v engines. you may have 20-30 PSI at idle but under throttle it will have 0 PSI.
If you don't have a gauge you need to get one.
1970 C/10 | Short Bed | 2wd | 12-Valve Cummins 6BT | 47RH Auto
Instagram | usetheBFH
Coal Chute http://c10forum.com/forum/showthread.php?t=19671http://
usetheBFH is offline   Reply With Quote
Old 03-07-2016, 01:36 PM   #4
NewMexCrew
NewMexCrew's Avatar
Thanks usetheBFH. How hard is it to install a fuel pressure gauge?
Old 03-07-2016, 10:54 PM   #5
COS399
COS399's Avatar
On my 88 R30 the rubber hose inside my fuel tank had not been removed and the rubber turned to mush and was restricting the flow. I removed the rubber line and everything below it and then extended the line down with a copper line and compression fitting. Hope you find the problem soon and good luck.
Keep us posted on your progress.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 03-08-2016, 11:30 AM   #6
NewMexCrew
NewMexCrew's Avatar
Thanks COS399. If weather permits I'll take a look at that this weekend. I might also just replace the lift pump and put the piston style lift pump right away. I will keep you guys posted.
Old 03-09-2016, 06:27 PM   #7
NewMexCrew
NewMexCrew's Avatar
93 12v Cummins swap sputtering under load
Meant title to read 93 12v Cummins swap sputtering under load
