Old 03-22-2016, 11:46 AM   #1
traymond73
Question 1972 C20 Big Block Engine Mounts
New to the board. Basic info before I pose my question:
1972 C20 Super Cheyenne with stock 402 and TH400
Swapping out engine for a 500 HP 468 and 3000 RPM torque converter
The truck appears to have the correct 1972 big block engine brackets.
My questions:
1. Do I need to replace both the engine mounts and the brackets? Or will just swapping out the mounts be enough?
2. My understanding is that the 1972s used a different mounting set-up than previous years. What is that set-up? pictures?
3. After seeing number 2 above, can someone point me to where the correct mounts for 1972 big blocks are actually sold?
Thanks in advance!
traymond73 is offline   Reply With Quote
Old 03-22-2016, 12:13 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 1972 C20 Big Block Engine Mounts
Welcome to the Board! Heres a link to Classic Truck Parts, http://www.classicparts.com/Motor-Mounts/products/310/
And heres "Manes Truck Parts" http://www.manestruckparts.com/store...Category_ID=16
The 72 mounts and stands are unique to the 72's and very pricey! I used the pre 72 stands with the common small block Chevy motor mounts, works great and is much more reasonable in price as well.~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-22-2016, 12:58 PM   #3
traymond73
THanks for the response. If I go with the pre-1972 brackets/mounts, then I have a couple of questions:
1. Will this change where the engine sits? If so, what problems will this cause, if any?
2. Will the small block set-up be adequate for the 500 HP?
Old 03-22-2016, 04:28 PM   #4
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
If you already have the big block motor mounts personally I would stick with them. I swapped out the rubber internals for polyurethane and bolted everything together with Grade 8 hardware.
The mounts you have are beefier but will bolt right up to the new big block.
If I remember right it took a little finesse and I had to install the bracket on the block the bracket on the frame and then I think the polyurethane was last as we bolted the clamshell together. Minus my helper up top taking a chip out of the firewall paint for not paying attention while I was under guiding the tranny in. It went well.
Don't forget to fill the converter first and I opted for an SFI approved flexplate just to be safe.
Good luck
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 03-23-2016, 09:18 AM   #5
traymond73
Thanks. I can't seem to find the polyurethane internals anywhere. can you point me to someone who sells them?
Good luck
Old 03-23-2016, 11:02 AM   #6
So.Cal.Super
It'll Buff Out!
http://www.summitracing.com/parts/pt...make/chevrolet
This is not the exact set, I bought mine years ago and it didn't come with the trans mount and I believe mine was made by energy suspension.
I always have to search 2 or 3 times and use 72 c20 suburban or some different combo including 71 because most parts companies computers if you pick 72 c20 400 it uses a small block.
but if you see in the pic those mounts are specific with the raised humps and how they sit between the clam shells.
Man Card Rules
1972 c20, big block swap, engine mounts
