Old 03-31-2016, 09:33 PM   #1
mctattooer
mctattooer's Avatar
Shifter linkage question
Got new column with shifter truck has floor shifter wanna go to column. Engine is 327 2 speed powerglide. Anybody know what i need as far as linkages from tranny to colum?
mctattooer is offline   Reply With Quote
Old 04-01-2016, 07:48 AM   #2
ksshane
ksshane's Avatar
Re: Shifter linkage question
Bumping so hopefully someone with more experience can help you out.
Not the same problem but.... I had to find a missing part for my clutch linkage and found that LMC has some pretty good exploded diagrams in their online catalog. You might start there.
Once you know what your looking for then you can post in the wanted section and Im sure you can find a used complete linkage from someone that has done the reverse swap.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 04-01-2016, 07:58 AM   #3
mctattooer
mctattooer's Avatar
Thank you
Old 04-01-2016, 11:28 AM   #4
57larry
check out Kugel Komponents. they have what you need for linkage. I have it on 2 of my vehicles
57larry is offline   Reply With Quote
Old 04-01-2016, 09:16 PM   #5
mctattooer
mctattooer's Avatar
Thanx but no luck says no power glide
Old 04-02-2016, 11:36 AM   #6
Mike C
Mike C's Avatar
Lokar might work, check theirs out. If you ever plan to do an overdrive trans (I WOULD!) now might be the time as you are redoing linkages as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
