Old 05-07-2016, 06:14 AM   #1
jctweedt
Vent window trim
Hey guys, question about my vent windows. A previous owner must have replaced one of the doors with a used one (maybe both) because one of my vent windows has black plastic trim and the other has chrome trim. I'm assuming it depended on the trucks trim level? Correct me if I'm wrong. Anyway, I was wondering if aftermarket vent window assemblies come with chrome trim or not. Also, is there a cheaper route to getting chrome trim for a vent window than potentially buying an entire assembly?
1972 Chevy K10 SWB w/ factory 307 and SM465 - DD project
jctweedt is offline   Reply With Quote
Old 05-07-2016, 07:02 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Vent window trim
Watch the classified section or place a Want To Buy ad ,on eBay they run about $250.00 for a nice used set needing gaskets or check with member Roger Koop he rebuilds them , what year is your truck ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-07-2016, 07:56 AM   #3
jctweedt
It's a 72 Custom. Thanks for the advice, I'll check ebay and will give Mr. Koop a shout if I can't find what I'm looking for.
Old 05-07-2016, 08:14 AM   #4
There is no trim on vent windows. You are referring to the window frame. If yours is a '72 Custom, then the painted frame is the original one. The chrome vents came on Custom Deluxe and up. Those trucks had stainless trim in the window gaskets, pedals, and aluminum centers on the dash knobs
Old 05-08-2016, 09:21 AM   #5
jctweedt
I gotcha. I called it the vent window trim because it's a part of the vent window assembly, wasn't sure what the actual terminology was. If I can't find a suitable stainless replacement for the passenger side, could I scuff up the trim on the driver's side and paint it black to match or would it be noticeably different? I wouldn't mind saving some coin as long as it would turn out well.
vent window, window, window trim
