Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-08-2016, 03:42 PM   #1
sweetk30
sweetk30's Avatar
1982 c-60 brake help
1982 c60 drum/drum man master on cab / vac /master down under cab . bbc power stick shift. non 2 speed rear.
friend just got this truck and its hissing when brakes applied under the cab .
its a man booster single line on firewall down to a vac booster master under cab .
its hissing from the vent/filter cab that comes from a 3/4inch hose off the black plastic unit off the master unit.
also I think the brakes need to be bleed out as the pedal is low and stays up if you pump it 2-3 times. I did check and the adjusters are up good and close so the shoes are about there on the drums .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-09-2016, 11:48 AM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: 1982 c-60 brake help
That hissing is normal
VictoriaHardware is offline   Reply With Quote
Old 06-09-2016, 03:19 PM   #3
sweetk30
sweetk30's Avatar
o.k. 10-4
guess will have to blead the brakes next and see what we get .
thanks !
