Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 06-14-2016, 07:09 PM   #1
sweetk30
sweetk30's Avatar
1982 c-60 brake upgrade help
I am working on a 1982 c-60 style truck .
its got man master single line on firewall. then vac/ master under cab . drum/drum brakes .
I would like to make it safer and work better with a 2 line master and hydroboost .
anyone with pointers on how to do this while I search here in my free time.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 06-14-2016, 10:40 PM   #2
rkn463
rkn463's Avatar
Re: 1982 c-60 brake upgrade help
Check out my build in my signature line. My 89 donor truck has 4 wheel disk with hydrobosst. Considering how easily parts swap on to the 68 I would think that 89 back to 82 wouldn't be a problem. I believe that Chevy motor homes had a lot of the same parts.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 06-16-2016, 06:14 PM   #3
sweetk30
sweetk30's Avatar
I am more use to 1ton hydroboost stuff and disk/drum master .
the truck I am working on had drum/drum .
could I use a extra hydroboost from a 1ton and a specific master to fit it and do drum/drum brakes. ?
Old 06-16-2016, 07:51 PM   #4
rkn463
rkn463's Avatar
I think with enough fabrication it would probably work, however the hydro boost unit from the medium duty truck is considerably larger and has a backup electric pump in case of p/s pump failure. I like the extra safety factor. I'll try to get one pictures this weekend.
-Richard
