06-23-2016, 01:49 PM | #1 |
Fuel System Advice Needed!
Help! I am looking for some advice from you gurus out there. I promise I have searched this site and a few others but can't seem to find an exact answer as many threads get so caught up in which fittings are what and so on.
I am trying to figure out my fuel system plumbing/routing. I have an F-Body tank with a fuel pressure regulator in the tank assembly. The motor is a 2002 5.3 Truck motor that is completely stock. This engine fuel setup is with a regulator on the rail and a return line. I understand I cant run two regulators. Is my best option to swap the fuel rail out in favor for the newer truck OEM return-less fuel rail and then run a corvette filter setup? I have two friends that know quite a bit about ls swaps and they both have differing opinions. Please help me. Thank you in advance! |
06-23-2016, 04:18 PM | #2 |
Post Whore
Re: Fuel System Advice Needed!
On mine I used a pushlock to -an fitting on the return rail barb and then put a -an cap on it..easy peasy..btw the corvette filter has a regulatory built into it.
06-23-2016, 09:13 PM | #3 |
What f body tank do you have? Early ones were for return type systems where as LS1 tanks have the regulator built into them. I believe that the later 98-02 6 cylinder cars used a return, but dont quote me on that. But if you have an LS1 pump, there is a line coming out of the tank that T's off a little ways out side of the tank and one line goes to the rail and the other goes back to the tank. You won't need a corvette filter/regulator with that pump, but I would recommend switching to a factory returnless rail if you do so.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-24-2016, 07:58 AM | #4 |
Yes, I have the LS1 fuel pump assembly with the fuel pressure regulator in the tank.
So basically you are saying get a returnless fuel rail on the motor with this pump set up correct? If that is the case how should I run the lines? |
06-24-2016, 12:07 PM | #5 |
Post Whore
You can swap the rail or cap the return..works either way..I haven't used a pump setup like yours..I've always used stock tank with external walbro and the vette filter/reg and the vette reg dumps back into the tank..
