Old 07-06-2016, 10:07 PM   #1
jr1000yarder
Need help identifying mirrors
I purchased these and I'm not sure they are what I thought....
Was hoping they are 69 below the eyeline mirrors.
Please advise.
Thanks, Rich
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 07-06-2016, 10:09 PM   #2
jr1000yarder
Re: Need help identifying mirrors
They are in awesome condition
IT IS WHAT IT IS
Old 07-06-2016, 10:10 PM   #3
jr1000yarder
I have all hardware and instructions
IT IS WHAT IT IS
Old 07-06-2016, 11:02 PM   #4
TwoFiftyShifter
R/V mirrors I believe.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 07-07-2016, 04:02 AM   #5
dazza
dazza's Avatar
I'm not sure if they were different in 69, but those look correct for a 72, mine has them listed on the SPID as:
- DG4 BELOW-EYELINE MIRROR
And that is what they look like. I've seen a lot of aftermarket versions that are different in the way they attach the arm to the head (diff rivets too).
Here is a shot of one mine.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 07-07-2016, 04:03 AM   #6
dazza
dazza's Avatar
Where did you purchase them? I may be looking for set in the near future.
Old 07-07-2016, 09:23 AM   #7
jr1000yarder
yeah,................damnit. I thought they were 71-72 mirrors.
I need the longer arms on the bottom for 69-70. The search for mirrors will continue.......I'll list these for sale. Thanks man.
IT IS WHAT IT IS
Old 07-07-2016, 09:24 AM   #8
jr1000yarder
They will be listed for sale in the forum in a few minutes....I got them with a parts lot I purchased. Exc condition.
IT IS WHAT IT IS
Old 07-07-2016, 09:30 AM   #9
georgieb51
georgieb51's Avatar
I do not see them listed for sale yet, but I will take them pending price of course. Thanks, George
georgieb51 is offline   Reply With Quote
Old 07-07-2016, 10:16 AM   #10
jr1000yarder
they are posted.....
IT IS WHAT IT IS
Old 07-07-2016, 11:00 AM   #11
FirstOwner69
FirstOwner69's Avatar
Your mirrors do not appear to be correct for 1972 either. The horizontal support the runs to the top edge of the door is not correct. Not sure about the legs, but they also appear a bit different. Measurements would help. There appears to be an additional "twist" at the door end in the support in the OP's picture. Here's a picture of an original 1972 DG4 mirror.
FirstOwner69 is offline   Reply With Quote
Old 07-07-2016, 11:15 AM   #12
jr1000yarder
Thanks! I'll measure tonight. I can def straighten the "twist" if needs be. the condition is just amazing. the lower legs are short like what was posted
IT IS WHAT IT IS
Old 07-07-2016, 12:51 PM   #13
FirstOwner69
Here's a short tutorial with things I've learned regarding the 1969-1971 DG4 mirrors referred to on early SPIDs as "W/C MIRROR-JR-LH&RH" and on later SPIDs as "BELOW EYELONE MIRRO".
I've found that there were at least 2 variations. Both utilize the same hole pattern in the doors. The information below is based on my 1969 originals and a set now on my 69 that I got from a 1970 GMC. The most common, by far, appear to be the type I got from the 1970 GMC.
Legs...
The first version legs were like the originals on my early 69 (picture 1). They were quite straight at the bottom whereas the second version bowed out from the door (picture 2). My assumption is that the bow was added to provide additional clearance with the upper beltline molding which (assumption #2) was first offered sometime during the 1969 model year.
Horizontal support to door...
My first version supports (picture 3) measure 6-7/8 ". The second version (picture 4) measure 5-1/4".
Mirror heads...
The mounting brackets on my original mirror heads were offset vertically which allowed the owner to raise or lower the head by flipping the mirror. Most others I've seen are centered. I have no idea when that change occurred or if mine are truly unique. In an earlier thread I read, someone claimed that this was a Ford design head, but I'm 100% sure mine are original to the truck.
See the next post for pictures of the assembled mirrors.
Old 07-07-2016, 12:53 PM   #14
FirstOwner69
Assembled mirror pics...
First... Original from my Dec., 1968, production 1969.
Second... From 1970 GMC.
Old 07-07-2016, 01:36 PM   #15
FirstOwner69
Here's a picture of a 1972 DG4 base showing dimensions.
Old 07-07-2016, 05:22 PM   #16
jr1000yarder
man where can I get a set of those.......I need them.
BTW my truck was built 10/68
IT IS WHAT IT IS
Old 07-07-2016, 05:39 PM   #17
FlameOut
Unfortunately that 'twist' is a bi#$% to try to straighten. I bought a set identical to those at a swap meet, thinking I could straighten than top mounting arm. I gave up
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 07-07-2018, 04:37 PM   #18
Jeff's72C10*
Active Member
Jeff's72C10*'s Avatar
I know this is an older thread. Was wondering what the measurements are for the holes from fwd part of door to center of holes for mounting. Recently picked up same mirrors for my 72 and need to install, thx for any help provided.
Jeff
Previous C10's
69 SB CST - sold
72 Cheyenne Super LB - sold
Jeff's72C10* is offline   Reply With Quote
