Old 09-05-2016, 09:42 AM   #1
dirish
dirish's Avatar
Fuel tank options? 72 Blazer easy swap?
Looking at replacing, what is the best option that
is a easy swap. Everything is factory 350/350.
Thanks in advance.
dirish is offline   Reply With Quote
Old 09-05-2016, 10:05 AM   #2
71swb4x4
71swb4x4's Avatar
Re: Fuel tank options? 72 Blazer easy swap?
Replacing with new? Buy a new 69-72 Blazer/Jimmy tank and swap the neck from the old tank onto the new tank.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-05-2016, 10:14 AM   #3
dirish
dirish's Avatar
I will read up. On pulling the neck from tank.
Old 09-05-2016, 10:26 AM   #4
71swb4x4
71swb4x4's Avatar
The old neck will come off very easy, I used a plumbers torch.
I had to take my new tank to a radiator shop to get the new one off, the solder they used on that one took a lot of heat to get off. It worked out OK because I wanted them to put the old one on the new tank anyway.
Of course be safe about it.
Old 09-05-2016, 10:48 AM   #5
71swb4x4
71swb4x4's Avatar
What's wrong with your old tank?
Old 09-05-2016, 12:42 PM   #6
dirish
dirish's Avatar
Nothing as of yet, but going to install a crate motor, and just looking into doing it all at once.
Old 09-05-2016, 05:03 PM   #7
71swb4x4
71swb4x4's Avatar
I wouldn't replace it then. If it's fine, leave it. I pulled mine just to clean it out, but with the hassle of the neck being wrong on new tanks I would much rather use an original tank. I cleaned mine and reinstalled it.
blazer, ful tank
