Old 10-16-2016, 12:33 AM   #1
67ChevNut
Show me your Boyd Welding Gas Tank Connections
I bought this gas tank a while back and I am just getting ready to install it. I know there are fuel line kits to use with it, what I like to see is specific pictures of the fuel line connections, and what fittings were used. Trying to find out if I should buy a fuel line kit, or if there are other ways to connect it. Appreciate your replies.
67ChevNut is offline   Reply With Quote
Old 10-16-2016, 08:15 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Show me your Boyd Welding Gas Tank Connections
I don't have pix but I just got -6 Russell fuel line from summit for feed and return. 20' is how I bought mine. Since I have an external pump, I had to buy more fittings but that's what I did and used dual line rubber lined hose clamps every 18".
Hope this helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-17-2016, 05:32 PM   #3
67ChevNut
Smile Re: Show me your Boyd Welding Gas Tank Connections
Thanks for the reply Clyde. I am contemplating different options right now, will look into yours. I went to Lowe's and bought a couple of fittings for my gas tank. Trying to see if I can do this without buying the complete fuel line kit. I noticed it doesn't have all the fittings I need so I will need to buy extra fittings if I go with the Tanks Inc EfI fuel line kit, or the Boyd Welding fuel line kit.
I want to do this as soon as possible. Looking at the twist-lok Russell fittings too. Just like to get a few more ideas. I will post whatever I ended up using. Thank you again.
Old 10-21-2016, 12:00 PM   #4
Jonce
Jonce's Avatar
This is the setup I ran on my '71.
Diagram of parts
Parts
I used the original fuel line vent from and mounted it inside my drivers side step side wheel well using the existing bolts.
I hope that helps.
Edit: I don't have a LSx in my truck (yet) but I'm running the FiTech fuel injection with the Boyd Welding tank
__________________________________
1971 GMC Stepside
350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar
Jonce is offline   Reply With Quote
Old 10-23-2016, 06:38 PM   #5
solidaxel
solidaxel's Avatar
Here is what I used, all the lines were from the Parker Store AN-6 and -8
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-24-2016, 06:08 PM   #6
67ChevNut
Thanks for that diagram and the picture, I will probably use half of those parts listed. Pictures help a lot, thank you.
I have not done this yet, but I was also thinking on using hard aluminum 3/8 pipe, flare it and use new fittings on the ends, I like the braided fuel line though. Not sure which way exactly to go yet, I know I have to buy the corvette filter. Once I get that I'll connect the fuel lines.
Like to try to spend as little as possible, lol. I'll post pics once I am done.
Old 10-25-2016, 10:45 AM   #7
zach_carver
zach_carver's Avatar
I used Russel AN fittings and braided fuel line. I don't have exact parts list though.. I pieced mine together from summit. I used the internal Aeromotive pump with my vette FPR also. Worked great so far and no more gas fumes!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
boy, fittings, fuel, ls1, swap
