Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Forums > Past Contest Winners > 2016 ToTM Archive
Old 10-16-2016, 07:56 PM   #1
November 2016 ToTM
Our November Truck of the Month (TOTM) contest theme is:
It Ain’t No Turkey
Here is the criteria for this month’s contest.
  • Open to all years and models of Trucks, Blazers, Suburbans, Tahoes, Yukons, and Jimmys.
  • It must be powered by a GM Big Block (gas, no diesel). This not only includes our lovable Chevy big block, but those by Caddy, Olds, Buick, and Pontiac.
  • The nominee must be a board member and the current owner of the truck.
  • The must be together and able to move on its own power.
  • The truck has to be licensed for street use.
  • If a truck was selected as a 2015 or 2016 TOTM winner, then you are ineligible. If the truck was nominated but not selected as a TOTM winner, then it may be nominated and compete in this month's category.
To Nominate:
You or someone else may nominate the vehicle. The nominee must be a board member and the current owner of the truck. Once you decide on who you wish to nominate, just add your nomination to this thread. We will need two pictures minimum (at least one full view of the vehicle) with/for the nomination as well as the owner’s board name, the Make/Model/Year of vehicle.
Nominations will run through October 24. The first 15 nominees that meet the criteria will participate in the contest. We will need at least one (1) picture of the engine and one (1) picture of the full vehicle. I will PM the nominees to get any additional data or pictures if they have not already been provided. If the owner has a preferred picture they want used in the contest, please let me know in a PM. You can PM me for an e-mail address in case anyone has problems resizing the pictures for the board. A Poll Thread will be set up by October 25 in this board area and an announcement will be posted on the Discussion Boards to notify all that voting has begun. The Poll will run thru the morning of November 1 and the official announcement of the winner will be on the evening of November 1. The announcement of the TOTM winner will be posted through the General Discussion Board area.
Old 10-16-2016, 09:53 PM   #2
VictoriaHardware
VictoriaHardware's Avatar
Re: November 2016 ToTM
Mk I Big Block - 409. 1965 C80. 28K miles. Original carburetor, distributor, alternator, & plug wires
VictoriaHardware is offline   Reply With Quote
Old 10-16-2016, 10:11 PM   #3
60-66
60-66's Avatar
1963 - 454
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-16-2016, 10:30 PM   #4
This one belongs to 65StreetCruiser
1968 with a 460 Chevy with T400
Old 10-16-2016, 10:58 PM   #5
lynx5653
lynx5653's Avatar
Our 90 GMC 3500 4x4
454 power lost pics of engine due to pc crash.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 10-17-2016, 01:47 PM   #6
4shongo
1956 Suburban- 454 Big Block
Body chopped 2" in rear, 2 1/2" in front,
- Roof Sectioned and lowered 2"to sit down over the drip rails
- All old flooring was cut out and replaced
- 3" mini tub to rear wheel wells
- American Racing Torque Thrust wheels (17x8 front- 18x9 rear)
- Tires; 255/45 front and 295/45 rear tires.
- Center pillars removed and replaced with one piece custom glass
- All glass is tinted custom cut tempered glass
- Hidden hinges on rear tailgate and remote tailgate popper
- Flush mounted third brake light on rear lift gate
- Shaved door handles
- Frenched-in 1965 Chevy truck rear LED taillights
- Truck has been lowered 4" all the way around
- Rear “C” notch
- Power rack and pinion steering
- Power 4 wheel disc brakes with CPP Remote billet reservoir
- Smoothed firewall and all wires hidden
- Smoothed dash and custom made metal center console with billet vents & AC controls
- All exterior emblems and trim has been removed and airbrushed on.
- Bumpers have been smoothed and tucked with no bolts showing
4shongo is offline   Reply With Quote
Old 10-18-2016, 05:47 PM   #7
RockTonka
RockTonka's Avatar
66 Burb
BBC with "stuff"
T400
Narrowed Dana 60 w/35 spline Moser's
28x15.5x15 Hoosiers
Drop spindles
4 Wheel power disc brakes
f & r sway bars
power steering
tooo much fun...
Thanks for the chance!!!
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
