Carbed LS swap Backfire
I have a stock 5.3 with a Holley carb. I have tested and researched about all I can find. I have talked to MSD and have also tried a Dayton Sensors smart spark with no luck. Everything I have done to this point has made a difference. But i still have a backfire through the exhaust at start up. Good grounds and 12v, new sensors... i have got rid of the misfire and have a good idle. I have tried different timing curves with the laptop. Im finally out of ideas so here i am looking for any help... I'm sure it's something simple..... also have good vacuum.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
Old member
Does it only happen when cold? If so check the bolts for the exhuast manifolds are headers which ever you are running. They may have a slight gap in them at startup but once warmed up they close up.
Just a thought. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Carbed LS swap Backfire
Check your cam sensor connector to make sure it's solid, though I doubt it would actually run otherwise.
Have you changed anything about the ignition tables? If your cranking spark were way off, it'd do that.
I'm going to try a different Cam sensor today.... I have tried different degrees of timing at 0 rpm
I don't know that ECM very well but there might well be cranking spark tables separate from the RPM based table.
