Old 10-24-2016, 07:46 AM   #1
Coronettom
65 to 87 front disk swap BAD wobble when braking
Hey all,
I swapped the front disk set up from an '87 truck onto my '65 c10...took everything but the actual crossmember...I know I need an alignment but when I brake I get a BAD death wobble that doesn't go away after I let up off the brake and I also have a pretty bad wobble from about 45mph and up.
Any guesses what I screwed up? Haha
Thanks, love this forum...
Tom
Coronettom is offline   Reply With Quote
Old 10-24-2016, 11:17 AM   #2
siggyfreud
siggyfreud's Avatar
Re: 65 to 87 front disk swap BAD wobble when braking
I would start with an alignment first. If you've changed the arms, spindles, etc, you really need to get it aligned before driving it very much.
siggyfreud is offline   Reply With Quote
Old 10-24-2016, 11:24 AM   #3
michael bustamante
michael bustamante's Avatar
did you double check the bearings? also did you replace the steer link assembly?
1967custom
michael bustamante is offline   Reply With Quote
Old 10-24-2016, 12:13 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Check alignment, check bearings and also did you resurface the rotors??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-25-2016, 10:43 AM   #5
Figuarus
Figuarus's Avatar
i'd make sure rotors are not warped, triple check bearings, make sure that the castle nut has a retaining pin.
Do you feel the wobble in the pedal or the steering wheel?
Get your alignment done first. that's the best starting place.
when you grabbed the 87 stuff, did you replace ball joints and tie rod ends?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-25-2016, 11:23 AM   #6
Coronettom
The rotors *LOOKED* almost brand new. So no resurfacing yet. And I ordered ball joints so I'm waiting on those, and I truthfully didn't even think about replacing the tie rod ends.
I went yesterday to see about getting it aligned but the shop wanted to charge me $1100 to replace a bunch of stuff first. So I supposed my next step is to start replacing ball joints etc...
When I check the bearings what exactly should I be looking for?
And I feel the wobble in BOTH the pedal and the steering wheel.
Thanks for all the help so far
Old 10-25-2016, 01:14 PM   #7
Clyde65
Clyde65's Avatar
If you question the inner and/or outer bearings and your unsure of their age, just replace with new. Your life may depend on that.
Clyde65
Rebuild of Clyde
support our troops!
Old 10-25-2016, 03:17 PM   #8
Figuarus
Figuarus's Avatar
lift the truck so the front wheels are off the ground.
Grab the tire and put your hands at the 3 and 9 o clock positions. Shake the wheel side to side. if you feel any play, or movment, you likely have bad tie rod ends.
grab the wheel at the 12 and 6 o clock positions, and do the same. Any play here may indicate bad bearings.
grab a long 2x4 or prybar and stick under the wheel. (it helps to have a helper here) lift the wheel and check for movement at the ball joints. If you have up/down movement, ball joints are worn out.
2013 Malibu LTZ
Old 10-25-2016, 03:30 PM   #9
Coronettom
Thanks for all the help everyone...I guess the good news is that none of these parts are too crazy expensive...truth be told it would have probably been a good idea to just replace this stuff from the beginning anyway...oh well, you know what they say about hindsight...
Thanks again, I'll try and remember to update when I get all this stuff knocked out.
Old 10-27-2016, 10:31 PM   #10
60chevyjim
60chevyjim's Avatar
check the tires too . if they are old radial tires they could have broken belts .
if they are old radial tires and you switched them from side to side this can cause the belts in them to brake and then they will wobble really bad .
radials should never change the direction they rotate , even more so when they are old and been rolling one direction for a long time .
60chevyjim is offline   Reply With Quote
