1961 Chevy k10 body swap
I really enjoy reading and following along on the build threads so I decided to start a build thread for this project . I also started posting on the 60-66 k series Facebook page . I have a 1961 Chevy k10 short bed step side . The previous owner must have put a 63 front clip on . It was originally from the coast the rust in the cab is terrible . I recently purchased a 1961 c10 step side short bed with a very clean body and only moderate rust in the normal spots . My plan is to swap the good body onto the k10 frame. The frame does need quite of bit of work before I can put on the new body . Bed mounts have been cut and moved and the front shock mounts have been distroyed and poorly repaired . I bought the k10 for $900 in 2000
Re: 1961 Chevy k10 body swap
Pulled the bed and front clip off this weekend . Got the cab ready to come off in the morning
![]() Join Date: Mar 2011
Welcome, and good looking truck!
But I may be biased cause I have had a 1963 short bed 4x4 for 35 years. I like '61 as well so witch ever way you go is good.
63 k20 with cummins 4bt, owned sence 1982 |
Ya , i would have stayed with the 63 but the cancer is completely through the entire drip rail and into the inside of the cab
Welcome also. nice to see another 61 k10. the new 61 looks like it's in good shape. looking for more of your build.
1961 chevy K10 my build is------------61K10 build |
Started taking it apart . Frame needs a bit of work . Front shock brackets have been broken and repaired several times it looks like very poorly . The rear bumper is welded on and the bed mounts have been cut and changed over the years .
Another
