Old 10-30-2016, 02:13 AM   #1
aussiejohn
Removing gear lever
Hi guys, I am about to replace the gearbox in my '67 GMC with a Turbo 700R4 and am stuck, I need to remove the gear lever from the transmission and don't know how. I CAN take off the top plate on the gearbox, but there must be a way to remove the stick only. Can anyone help please?
Regards from Down Under:
aussiejohn
aussiejohn is offline   Reply With Quote
Old 10-30-2016, 07:59 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Removing gear lever
Push down on the domed ring and twist. You should be able to pull it right out.
low'n slow is offline   Reply With Quote
Old 10-30-2016, 08:11 PM   #3
aussiejohn
Thank you Sir. I logged on and saw your reply no more than four minutes ago. I went out, followed your advice, and out it came!
I am in your debt.
Regards from Down Under.
aussiejohn
Old 11-01-2016, 07:35 PM   #4
low'n slow
low'n slow's Avatar
You are welcome.
