Check list for crate install
OK mechanic has motor at the shop, waiting for
A little space, then he'll start. I would like to buy The break in oil, filters, and other fluids in advance. I will have him install the new transfer case as well. I have the seals/gaskets, but need fluid. Any help on a list would be great, I'm not a mechanic, and don'twant to miss any thing. Sbc 350/290hp th350 4x4 1972 Blazer Thanks Dan |
![]() Join Date: Jul 2016
Re: Check list for crate install
On any new install that I do here's my list.
New water pump. Not a fan of Reman Spark plugs. A/C delco Spark plug wires.. Thermostat New Belts New Hoses including Heater hoses. Make sure motor mounts are good. Alot easier to change now for not much money Nothing worse than getting that new motor looking great and having to tear it back apart to fix a misfire or get it all dirty from a coolant leak. Then you should be good for at lease another 60k Last edited by NRFD79; 12-08-2016 at 10:45 AM. Reason: more info |
#3 | |
![]() Join Date: Nov 2004
Is this mechanic a friend or an actual shop?
If a shop, I would tell them you want the motor broken in properly with break in fluids. When you supply the materials for a shop to use, you set yourself up for liability. If the engine fails on start up, they can claim you gave them the wrong oil, etc. A great example is windshields, if you have a shop install one and they break it, it's on their dime. If you supply the windshield and they break it, you're paying for another windshield.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Not sure what oil you use after break in But I highly recommend brad penn if you can get your hands on it. We use it on all older cars and trucks. Has a high moly count to protect your cam. Comes out of the bottle a dark green looks dirty but its the good stuff.
#6 | |
Using Joe Gibbs "Driven 10-40" . All the test analysis show it very high in quality. The also make a oil for our old stuff, for the daily driver oil, high in zinc. |
She's off to the shop, new transfer case as well.
I didn't drive it cause it was 36 degrees, and my son Was going with me. |
Tags |
break in, checklist |
