Old 12-05-2016, 12:13 AM   #1
KyleSeal
KyleSeal's Avatar
Any Reviews of These Headers? (Summit Racing, Hedman)
https://www.summitracing.com/parts/h...del/c10-pickup
Found these, seems some reviews say C10s are what they have them on.
I'm running a standard '70s 350 and a Saginaw 3 speed, will these clear the bellcrank and such? I have it converted to floor shift, so no linkage from the column.
They seem affordable, and I've heard good stuff about Hedman. That said... what is everyone elses take?
Going on a 70 C10 with a 5.5/7 drop 350 V8 3 Speed Saginaw Hurst floorshift.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 12-05-2016, 04:57 AM   #2
69vetteside
69vetteside's Avatar
Re: Any Reviews of These Headers? (Summit Racing, Hedman)
I just installed them on my 69/350 turbo 400. good headers heaps of room.swapped them for the hedman long tubes i had on (had to modify to fit between the frame rails and around the bottom arms)and were to low for the amount i lowered the truck . Other than that Hedman are good headers.
69vetteside is offline   Reply With Quote
Old 12-05-2016, 08:53 AM   #3
Those don't look like they'd work with clutch linkage. You need full-length with the rear tube dropping straight down or slightly forward. 3/4 length headers run right through where the bell crank assembly is.
Old 12-05-2016, 12:08 PM   #4
demian5
demian5's Avatar
Throw the collector bolts in the trash and get grade 8 with locking nuts. Trust me.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
70 c10, headers, hedman, mid length
